Old 10-22-2009, 07:06 PM
Johnny3000 Johnny3000 is offline
Boost gauge not working
Any ideas I look around but most just sugest replacing everything with after market which I probally will do later but either way I would like the stock one to work
Old 10-22-2009, 07:20 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Boost gauge not working
It's not worth your time to locate the problem and fix it. The stock boost gauge is not in any way accurate. It's most likely a sensor that's the issue. Just get a mechanical boost gauge for about $50-$60 and tie it into the vac system.
Old 10-22-2009, 07:26 PM
Mechanical 'o' I thought the moto around here was go broke or go home do they sell electronic aftermarkets that fit the dashspot? Or is it not worth triin to find one?
Old 10-22-2009, 09:38 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
There are gauges that fit the stock locatation but its like 2-3 hour job if not more i believe to get to them. Stealthee or someone else can tell you more bout that.
Old 10-22-2009, 09:50 PM
Polygon's Avatar
The Red Baron
The best boost gauges are mechanical. The shitty stock gauge is electric. The moto around here is be smart or go home. Just spending a lot of money doesn't make it a good idea.
Old 10-22-2009, 11:21 PM
Stealthee's Avatar
Stealthee Stealthee is online now
Your worst nightmare
My motto is do it right or don't do it at all.
Old 10-23-2009, 08:18 AM
Yeah that why I ask so many questions so I only have to do it ounce it's just that the right way isn't ussually cheap quality parts generally have a quality price tag and I guess when I said electronic I really ment digital
Old 10-23-2009, 08:19 AM
But you guys think mechanicals are more accurate?
Old 10-23-2009, 12:17 PM
Polygon's Avatar
The Red Baron
Here's the skinny:
Digital/Analog: These are just two ways of reading out the information. Digital will cost more and is just eye candy, no benefit.
Electronic: The means that the gauge gets it reading via a sensor. This is the way the stock gauge works. Once again, more money, and not worth it for a boost gauge.
Mechanical: This get's it reading directly with no electronic crap to get in the way. In the case of a boost gauge it reads directly off the manifold pressure and the gauge is just a simple vacuum gauge. It is the ideal boost gauge. Other gauges are better in electric, just depends on the gauge.
Old 10-26-2009, 06:58 PM
AutostradaVR4 AutostradaVR4 is offline
even though i had issues with my Prosport Electronic Boost gauge, i would still recommend it.
For one thing, it's cheap.
Secondly, it looks good.
Third, It's easy to install because you dont need to run vac line through the firewall, just 1 skinny little wire.
and Last, in the event that something does go wrong, Prosport has outstanding customer service. They replaced my gauge and sensor without any hassle.
The stock center cluster gauges are 52mm, but 60mms will fit
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 10-27-2009, 07:51 PM
Unhappy Re: Boost gauge not working
prosport it was a 52 mm had a blue indicator light that goes yellow to red as a warning I think it was good up to 30 psi
that one I was thinking about
was the second one ok or did you send it back
Old 10-28-2009, 10:13 AM
second one worked perfectly. you can find pics on my cardomain page i have linked in my sig.
Formerly BlinkRA182
