Old 04-07-2003, 08:18 PM
bradfordtheguy bradfordtheguy is offline
Send a message via AIM to bradfordtheguy
Srange sound when hit a small bump...
okay, everytime i hit a small bump in my 99 GASE2 at a low rate of speed, it sounds as if there is something rolling around. The sound seems to be coming from near the tire well, possibly near the struts. just wondering if anybody out there has the same experience as i...
Old 05-21-2003, 02:36 PM
kering kering is offline
I hada similar noise (sounded like it was between dash and front passenger tire). It almost sounded like the tire was going to fly off. Took it to shop, couldn't find the problem. I haven't heard the noise in a while now, it just sort of disappeared.........??????
Old 05-21-2003, 10:01 PM
Scott 02's Avatar
Scott 02 Scott 02 is offline
Banned
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
just the struts, they do that sometimes when new. not sure why. My grand prix had that problem once. It fixed itself
Old 07-06-2003, 01:30 PM
GA LOVER GA LOVER is offline
Strage sound when hit a small bump
Hi there. This is my first time using this forum, but it's pretty informative. I too can hear the sound, which does sound like it's between the dash and the passenger side wheel well. I've thought it was the CD player, things rattling in my glove box, but thought it probably had to be the struts. I bought my 2000 GA SE about a month ago, from a great place in Canada called Car Canada. They totally recondition the car and do a 144 point inspection. Anything wrong, they replace. The tires-brand new-still have the tire hairs. Brakes-brand new, and so on and so on. I wonder about little noises-are they because they are being broken in or are they just broken.
I also have a very annoying sound when I come close to a stop. The front end makes a sqweeking noise, but it sounds like when your suspension is shot. It's like the pedal is a big rod that is rusted or needs to be lubed. It's hard to explain. Any way, I love GA's no matter what anyone says, because every car is going to have problems, and I'd rather these little problems than the " Engine drops out when reaching 60 MPH" problem that I've heard about on the Ford Focus that I thought I wanted.
Old 07-10-2003, 02:40 AM
LE~Daddy LE~Daddy is offline
Question
I have a similar problem when I come to a stop when applying my breaks...sounds like a creaking noise like a bad spring.
Old 01-16-2005, 03:04 PM
Ubart Ubart is offline
Re: Srange sound when hit a small bump...
I have a 95 GASE, same creaking noise in front/driver side. Seems to be worse when cold, especially if wet and cold. I think bushings cause the problem, I'll let you know when I get it checked this week.
Old 01-16-2005, 06:19 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Ubart, Exactly what the hell spurred you to resurect a 2 year old thread? LOL. oh well - I would say lube your bushings / tighten all bolts on all your control arms and see if that helps any.
Old 01-17-2005, 11:01 AM
will do, thanks
I'm new to this site, just bought the GASE a couple months ago, and of course am encountering the usual problems. I didn't check the date of the post, I was just interested in what was said. I'm surprised anyone replied, now that I know. Thanks .
I'll definitely try the bushings and control arm. That sounds about where it would be coming from.
Old 01-17-2005, 12:41 PM
Ridenour's Avatar
GranddAmnit
Oh no problem ubart. Yeh, those would definately be my guess. Enjoy your GA and good luck with the suspension
Old 01-17-2005, 09:02 PM
lionelkirk2004 lionelkirk2004 is offline
Send a message via Yahoo to lionelkirk2004
I have that same problem on my 1996 Pontiac Grand Am. I have no clue what it is but it the noise comes from that same area.
Old 01-17-2005, 10:18 PM
troy1 troy1 is offline
AF -Advisor
make sure all your bushing are in place!!!
Old 01-17-2005, 10:34 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
If you have steel wheels with the plastic wheel covers they will make a "crack" sound in the front every time you hit a bump because they vibrate against the rims.
Marc
MECP Level 1 Installer
Mobile Dynamics Corp. Certified Installer
Clifford Electronics Cetified Mobile Security Installer
Electrician in training
'01 GA SE, Stock....for now.
SudburyGrandz
Old 01-17-2005, 10:36 PM
Well ridenour, now I see why this thread took so long to open!!!!! Interesting vid you got there.
SudburyGrandz
