Old 10-22-2009, 05:18 PM
Elitemduane12 Elitemduane12 is offline
Replacing rear pads and rotors 01 Grand Prix
I have an 01 grand prix se Im changing the rear pads tommorrow, and possible the rotors. I have changed the front before but not the rear. I was wondering exactly what tools I will need to change the rear pads and rotors. Not sure if I will need to replace the rotors yet, but there is a grinding noise now when a break. Sizes would be appreciated.
Thanks a lot
Old 10-22-2009, 05:56 PM
The_Mechanic_33's Avatar
The_Mechanic_33 The_Mechanic_33 is offline
Re: Replacing rear pads and rotors 01 Grand Prix
You have a P.M. in your inbox.
Any more questions ask here.
http://www.alldatadiy.com/about_alldata/index.html
Please post: Year,Make,Model,Engine Size.
Old 10-22-2009, 06:02 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
If you can do the fronts, the rears are a cake walk.
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 10-22-2009, 09:30 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
I agree. I think the bolts are 13mm and 14mm for the bridge and guide bolts. I forgot which is which. Of course you will need a 19mm and breaker bar to get the wheel off, and you might need a 5lb hammer to break the rust bridge and get the rotor off the hub.
My guess is that if they are grinding, you are going to need to replace the rotors for sure. When I do brake jobs, its never a question, I always replace the rotors. They are cheap enough nowadays.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-23-2009, 12:35 PM
Thanks for the replies.
Old 10-25-2009, 05:24 PM
CraigZerch CraigZerch is offline
The back should be easier than the front, good luck with your repair.
