Old 10-22-2009, 10:11 AM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Torque Converter Questions...Again
Hey,
That surging RPM problem I talked about (link below) is slowly getting worse and worse. The good news is that the more obvious it is, the easier it will probably be to diagnose when I finally have to take it to a shop. I've been thinking about it more and assuming it was a torque converter problem, what could I expect in terms of repairs? I know that's kind of vague, but I don't know a whole lot about transmissions and so you'll have to forgive the dumb questions. Can a torque converter and/or solenoid be replaced, or does it require a whole new transmission? If these things can be replaced, what would an average cost be? I might be at a point where I will just go trade it in for an '03 while there's still some value in it, I dunno.
Sorry to beat a dead horse, but it's not quite dead.
http://www.automotiveforums.com/vbul...d.php?t=961713
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 10-22-2009, 11:12 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Torque Converter Questions...Again
oh man, I don't know. depending on what is exactly wrong with it, The solonoids can be replaced by just removing the side cover. Still a PITA and a big job, but cheaper than a full rebuild.
Have you tried running sea-foam trans additive through it for a week and then doing a pan drop, filter and fluid exchange?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-22-2009, 11:22 AM
00GTP4ME's Avatar
No, I did the filter and fluid change not too long ago, so I'll keep that one in my back pocket for a bit and see what happens. You know what I realized I never did?? In that other thread I had going, you suggested that I clean the MAF and then unplug the battery for a night, right? I cleaned the MAF, but I totally forgot to unplug the battery! I wonder if a reset would help since I put the stock air box back in and cleaned the MAF! Hmmm... I'll probably do that tonight! I'd die if that fixed it.
That seafoam additive- does it make the car run (shift) like crap while it's in there? What does it do exactly? It won't "shock" the transmission like a flush does, right?
Old 10-22-2009, 08:26 PM
tblake's Avatar
In God We Trust
Its a detergent, it cleans out all the fluid passageways in your valve body and solonoids. I think it thins out the trans fluid which is why its not recommended to keep it in for too long. I'm pretty sure it wont "shock" the trans especially if you have already done a fluid and filter change. I don't know though. I usually dont like messing with trans's unless there is a problem.
Old 10-22-2009, 08:27 PM
tblake's Avatar
In God We Trust
Give the battery idea a shot and see what happens. Whats the worst thing that could happen? You have to reset your radio presets?.....
Do you happen to have an aftermarket PCM or throttlw body?
Old 10-23-2009, 11:14 AM
00GTP4ME's Avatar
Hmm. Well I can't image that it would make things worse as long as I do it right before I change the fluid and filter. I'll keep this in mind...
Yeah, I'll try the battery. Stupid question, but should I just take off the positive battery cable? Also, out of curiousity, will different things reset and to varying degrees depending on how long you leave the power disconnected?
I'm 99.9% positive that everything on this car was bone stock when I bought it. No tint, no customized anything. As a fatter of fact, when I bought it, the dealership told me the previous owners were from MN! Must be home of the Grand Prix or something. (The bad thing is that the leather seats really don't like the dry Utah air at all).
Anyway, no, I'm fairly positive the PCM and throttle body are original.
Old 10-23-2009, 12:56 PM
tblake's Avatar
In God We Trust
Yeah, thats why sometimes it works, because unplugging the battery overnight forces the computer to re-learn. It actually may run different for a week or so. No need to disconnect the positive, only the negative (unless you really want to).
Old 10-23-2009, 01:44 PM
00GTP4ME's Avatar
K. I'll give that a shot and will let you know how it goes. BTW, what's the story with your 161 MPH HUD picture? Were you cruising down the road at 161 with your gf holding the wheel while you held the camera?
Old 10-23-2009, 02:47 PM
tblake's Avatar
In God We Trust
HAHA, No man! 100% Photoshop! I was actually cruising at 61mph and snapped the picture with my cell phone, got home, and copied the 1 over..... Same with the speedometer, all photoshop. The product of too cold of MN weather to be working on it and too much time on my hands.
But the "grand prix" painted calipers are all for real, no optical illusions there.
Old 10-23-2009, 04:34 PM
00GTP4ME's Avatar
Ha, ha, ha, yeah, yeah, that's the oldest excuse in the book! "Son, do you know how fast you were going back there?" "No officer, it was photoshop, I promise!"
Instead of a "1," you should have put a "2" and just lied about it. Then you should have put your tach needle WAY past the red zone. That would be hilarious.
Did you get those caliper decals off ebay (they look familiar)? I was going to buy the GTP ones, but decided to make my own. I painted my calipers blue and then put white "GTP" decals on them. It looked pretty cool until winter came around and then the salt pretty much ate everything off, so I need to redo them. I was thinking about just getting those caliper covers because I'm lazy, but I'm not sure if the rim will hit them or not.
P.S. If you're handy with photoshop, you need to straighten your GTP badge picture.
Old 10-24-2009, 12:44 AM
tblake's Avatar
In God We Trust
Yeah, HAHA! I actually wanted it to believable, so I just went with 161. HAHA!
The decalls actually came from a website called afterthought auto for 20.00 even shipped. I could not find them on ebay anymore. I was hoping to get "supercharged" ones, but no such luck, so I had to settle for "grand prix". They look pretty good, they are thick decalls and actually chrome, so it looks pretty hot on the black calipers.
My g/f and I have DIBs on how long they will stay on there during the winter months. My bet is that after the first hard snow and salty roads, at least one litter will peel off. We'll see..... I'm not too worried if the decalls come off, but I will be sort of irritated if the paint flakes. I have 2 thick coats on each caliper.... only time will tell.
I have not heard of caliper covers before. But like you say, there are pretty close clearences so I would be afraid of them hitting the wheels.
How did the unplugged battery turn out?
Old 10-26-2009, 04:17 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
lol, tim...i kinda wondered about that. i thought maybe you had just switched it so that it was reading in KPH instead of MPH.
Old 10-27-2009, 12:37 PM
00GTP4ME's Avatar
Well like you said, it did start up and drive differently. I left it disconnected all night and then hooked it back up before going to work. The only "bad" thing is that we got our first snow of the season today so I wasn't able to drive...dynamically enough to play around with the torque converter engaging/disengaging (lots of slow-moving cars on the road). From what I could tell it did seem different. When I did get on the freeway the torque converter seemed to engage sooner than it usually did before. I also had a brief moment where I reached the speed/condition where it would normally do it's surging thing and it didn't do it. It was only for a brief moment and waaay too early to tell if this solved or remedied the problem. I'm going to keep a very close eye on it the next couple of days and will let you know what happens.
Oh, and while on my way to work, I took a picture in honor of Mr. Blake:
Do not attempt at home, especially in the snow....
Old 10-28-2009, 12:17 AM
tblake's Avatar
In God We Trust
Good luck, keep me posted on the TCC issue.
96? haha! That wasn't in the snow was it?
Old 10-28-2009, 10:02 AM
00GTP4ME's Avatar
Ha ha ha ha! It does look like 96, doesn't it!! It's actually 36! I didn't photoshop that or anything! And yes it was snowing! Can you imagine going 96 in the snow approaching that little curve! Ha, ha, ha, wouldn't be pretty!
I will keep you updated. Drove it some more yesterday and it still didn't do it. I'm going to school tonight and that will give me more driving time. Keep your fingers crossed...
