Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-21-2009, 09:29 PM
98spyderman 98spyderman is offline
running hot
so my stuff just ran hot. and i limped it back to the house but i have put water in the over spill and in the radaitor. but it still running hot it will be fine for a sec then the neddle goes up anyway i think that it is the thermostat let me know what you guys think
Old 10-21-2009, 11:09 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: running hot
Probably blew the HG. Check to see what color your oil is.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 10-21-2009, 11:53 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: running hot
Sorry your losing water?
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 10-22-2009, 07:47 AM
Re: running hot
no i am not losing water and i am not leaking any fluids i thought that it was the head gasket to but my car isn't smoking so i dont think that it can be that. but last night i was working on it. i filled it up with water both in the over flow and in the radeator and started it up, it didnt run hot just sitting there but when i started to drive it, it started to run hot i still think that it is what i orgnially said but let me know if you come up with something else to look at
Old 10-22-2009, 11:25 AM
Re: running hot
Did you check to see the color of your coolant and/or oil yet?
95 Eclipse GS-T
Currently:
Soon lol
Old 10-22-2009, 01:52 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: running hot
5 bucks says he didn't.
Do the fans come on?
Does the t-stat open?
Is the rad cap faulty?
Kris
2012 Genesis Coupe 2.0t
Old 10-22-2009, 07:05 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: running hot
+1 on the radiator cap. They are cheap, and is what lead me to blowing my head gasket on the talon. Is coolant boiling out of your overflow tank? If so you might definately want to replace that. The thermostat is also an easy fix, so I would start with those two things to narrow it down. If you are not burning coolant, and your oil is coolant free (vice versa) then you haven't overheated anything too seriously yet.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 10-23-2009, 01:28 AM
Re: running hot
+1
Anytime someone mentions overheating, the first thing I say is change your T-stat and Rad cap. Its cheap, and they probably need to be replaced anyway.
Caleb
vanilla gorilla
Old 10-23-2009, 06:47 AM
Re: running hot
This doesn't, however, mean the HG isn't shot. My coolant and oil are fine, but I'm pressurizing the system and I'm 99% sure it's from the head lifting on an improperly sealed gasket.
Still makes good power, too.
Kris
Old 10-23-2009, 11:57 AM
Re: running hot
What leads you to believe your head gasket is shot then if nothing is burning or mixing? I suppose if you can watch the coolant in the radiator or fill point and if it bubbles, that could be another sign. Maybe a compression test to see if compression from one cylinder is leaking into another cylinder? Mine was pretty obvious when I saw a steady pressurized stream shooting out between my head and my block, so no troubleshooting there.
94 Talon 1.8L-SOLD
Old 10-26-2009, 07:08 AM
Re: running hot
Leakdown and compression testing will determine this.
Kris
