Old 04-07-2003, 06:16 PM
Kakarrott Kakarrott is offline
Question NO power
I put in my B16A first gen into 90 civic si hb it has CTR piston with rings and skunk 2,s springs and retainers for now,Everything is almost good execpt for these problems:first my distributor cap is move all the way forward to make the idle come down to 1,000 RPM and goes up to 1,500 once its warmed up and stays there i messed around with the air adjustting screw on the carb its screw in all the way and still idle 1,5000 rpm and once i run for more than 1 hour the IDLE starts to fluctuate up and down i know it might be the IAC or the FITC might. 2 ? is my power is not there i take it to 5,000 rpm and it seems to me like it not enough air or to much i still have the stock exhuast from catalyc to muffler i do have JDM headers 4-2-1...........PLease Help Me.......thanks
Old 04-07-2003, 06:34 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
what ecu are you running? it seems as tho its not controlling your motor right, or was wired up incorrectly.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-07-2003, 06:47 PM
I have the PR3 and at first i did install the vtec wire all backwards but its all fixed i used hasport vtec wiring, Im really lost.
Old 04-07-2003, 06:56 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
If i recall correctly moving the distributor towards the front of the car retards the timing which is the reason that you have no power. I would get a timing gun and set it back to the stock range. The idle sounds like you do have a bad IAC.
Old 04-07-2003, 07:56 PM
i have to move it foward cuz if i put it in the middle or backward wich is advance it IDLES way to high like 2,000 rpm i will try another iac if it works w00t and if it dont them im gonna check ECU.Ok heres the deal i checked timing with my gun its fine but if i put the distributor in the middle the iidle begins to fluctuate up and down and idle is way high normal IDLE is 700rpm.
Old 04-07-2003, 08:05 PM
crxlvr's Avatar
maybe your tps is screwy too.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-07-2003, 08:41 PM
i checked it tps i get no errors i think its goin to be th IAC most likely or FITC i disconnected the IAC while the car was on and it all went normal but when i hit the gas and try to keep it at a stedy IDLE it would fluctuate know i pluged it bak in and guess what its now giving me error 14 IAC sensor i tried to reset the ecu but with no succes i guess its the IAC then.
Old 04-07-2003, 08:49 PM
95civicman 95civicman is offline
try settin your timing back to stock or where you are gettin the high idle and then loosen up your throttle cable?? it should bring your idle down and then go take it for a test run and see if you have you power back.
zc powered 89 CRX SI with some more stuff.
Old 04-07-2003, 09:00 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
possible injector leaking...i have one or more injectors leaking and have the exact same symptoms that you do....check your fuel system.
Honda...An Army Of One
Old 04-07-2003, 09:33 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
I have the same problem but my rings are shot to hell.
