loud clunk
i have a 96 lasabre.when i turn left u can hear clunk and it pulls u left .after straighting out steering wheel is is turned 2 the right for a short distance then clunks again and steering wheel is centered.all 4 struts i replaced .replaced both sway bar links.had it aligned. it dosent click click click like cv joint
Re: loud clunk
Check your engine/tranny mounts. The entire assembly could be shifting during turns and creating the clunk.
Re: loud clunk
Did you inspect, or replace the front strut mount bushings & bearings?
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Re: loud clunk
bearings and bushings good.spinne 1 feels like its in the steering the way it clunkes and locks the steering 4 a short time .mayb lower ball joint?mayb rack and pinion loose?thanks 4 the help
Re: loud clunk
I assume ball joints are in good shape also?
Re: loud clunk
not sure about ball joints.i did jack it up and tried moving tire.didnt feel any movement at balljoint.hmmmm
Re: loud clunk
Re: loud clunk
Another way to check the front end is to lay on the ground with a light and have someone turn the steering wheel all of the way to the right and then all of the way to the left. Keep doing this, back and forth. If the ball joints are bad, you can see them move out of the socket when stressed all of the way left or right. You can also look at the tie rods for extra movement. It sounds like it is too dangerous to drive as is.
