Old 10-21-2009, 12:18 PM
Hendrix31 Hendrix31 is offline
Exclamation 93 Lasabre dims quit working
The dims quit working (both of them) all of the sudden. I have replaced the light switch assembly in the door as the manual said the only fuse was a blow circuit in that.
The parking light work and the brights work.
Please help
Old 10-21-2009, 02:10 PM
imidazol97 imidazol97 is offline
AF -Advisor
Re: 93 Lasabre dims quit working
Originally Posted by Hendrix31 View Post
The dims quit working (both of them) all of the sudden. I have replaced the light switch assembly in the door as the manual said the only fuse was a blow circuit in that. Please help
I would look at the dimming switch, which I believe is at the bottom of the steering column. When you pull up and down on the turn signal that pulls a link that switches between bright circuit and low beam circuit. I believe, I believe that switch is down on the steering column. You can check to see if voltage is coming out the wires there for the dims.
