Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 10-20-2009, 10:40 AM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
new project need advice
its a 95 sohc mtx with 4 wheel disk brakes and a few other options needs body work struts tires and a head (only 100 bucks thow)
im going in a perfomance orented direction but also daily driver
this is what i need to know what year head should i get i know some had different cams and such (the original head has burned valves and bad scaring on the cam) ialready know the basics like the atx tb , header exhaust i plan to port the head (only 60 bucks from local junk yard)
are there any other cheap performance mods i might not know about i have done a bit of googling so i have lots of info any tips would be great
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 10-20-2009, 02:08 PM
mopar_rocks mopar_rocks is offline
Re: new project need advice
As far as I know, the 95 cam is alittle bigger than the 96 up cam. I too am doing the same thing as you right now. I think I'm just gonna go with the 95 cam ... although I've heard something about a Magnum cam from later models but I'm not sure which years they were in. Good luck with your project.
Old 10-21-2009, 07:50 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
The magnum cam from the 01+ ACR or R/T is a more agressive cam than the 96-00 cams. You can use DOHC pistons to slightly raise compression. If you can polish the head when you get it ported, DO IT. Makes a nice difference. You can also build your own 3.0L intake, DOHC muffler, oh and get a Performance PCM.
2003 Dodge SRT-4
Old 10-21-2009, 05:49 PM
thanks for the responses so would the entire head off a 01 and up r/t bolt to my lower half (i will try to go this route if so) its too bad my 95 cam is trashed , i have no plans to do the lower half, i may have the head milled down a bit to bring up the compression the ecm may have to wait im on a small budget but for a muffler i had a glass pack left from my camaro so that is going on ill be doing the port work on the head myself so ill be polishing it as well (did my camaros heads turned out pretty good) i will keep you guyz up to date ive tore out the interior and doing some costom stuf to the wheels (same as das2123's now) probly going to lower it a few inches also
Old 10-21-2009, 05:54 PM
heres a few pics for now i plan to paint it dark red
http://viewmorepics.myspace.com/inde...ageID=38563480
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=138686322& albumID=2343656&imageID=38563482
http://viewmorepics.myspace.com/inde...ageID=38668408
http://viewmorepics.myspace.com/inde...ageID=38668413
Old 10-21-2009, 10:16 PM
Nice!! I'll be watching this thread just to watch the progress! Nice!!!!!!
Old 10-22-2009, 07:38 AM
You can use a magnum head but there are some differences. The 01+ heads don't have an EGR and I am not sure about valve covers. You could get around the EGR by upgrading to a Mopar Performance PCM anyway!!!
2003 Dodge SRT-4
Old 10-22-2009, 02:32 PM
so the mopar ecm automatically delete the egr or do i have to specify when i order
Old 10-22-2009, 02:33 PM
It doesn't even look for it.
2003 Dodge SRT-4
Old 10-22-2009, 04:38 PM
cool kinda pricey thow any other way around it
Old 10-22-2009, 06:59 PM
You can not use it, if you don't mind living with the CEL lit all the time. Although, people have reported no CEL after removing or blocking off their current EGR.
2003 Dodge SRT-4
Old 10-22-2009, 09:28 PM
if the light is is on will it effect performance/ fuel economy ("limp mode") if not i can deal with the light
Old 10-23-2009, 06:42 AM
It won't affect performance at all. It will light the CEL because the PCM won't get a reading from the EGR.
You can also use a resistor to simulate the load on the EGR to help keep the CEL from lighting.
2003 Dodge SRT-4
Old 10-23-2009, 10:23 AM
cool what ohm resistors do i use and will the light stay off
also some update pics
http://viewmorepics.myspace.com/inde...ageID=38718019
http://viewmorepics.myspace.com/inde...ageID=38718014
http://viewmorepics.myspace.com/inde...ageID=38718016
http://viewmorepics.myspace.com/inde...ageID=38718018
Old 10-23-2009, 10:26 AM
10 watt resistor.
2003 Dodge SRT-4
