Old 10-19-2009, 06:47 PM
camrs96 camrs96 is offline
96 camaro high temp at idle
96 chevy camaro 3.8. i got a problem with the idle tempature, just peplaced the water pump and thermostat (180 degree). when driving around the cars stays at a constant 180 temp but when sitting and idling for more than 3 or 4 minutes the temp starts to climb and gets up to about 230-240 which i know is not good but thats when the fans start to kick on. the system is clean all new antifreeze, no air in the system everythings ready to go. iknow its not normal for the temp to climb that high does anybody possibly know what else could be cause this high temp at idle?
thanks
Old 10-19-2009, 07:14 PM
Scrapper Scrapper is offline
AF Premium User
Re: 96 camaro high temp at idle
you can try changing thermostat and see if that help's or have you already?
Old 10-19-2009, 07:44 PM
yeah this is the second one ive tried. i actually had bought a thermostat that opened up at 192 cause thats what they told me the car called for but when i put that in the car would heat up to 192 the fluxuate back do to 180 and it would do this repeatedly, i wasnt happy with that i actually thought that it was a defective thermostat so i brought it back and i had purchased the 180 degree, i was a little more comfortable with that temp cause i originally thought that 192 was high? but anyways yeah its got a brand new thermnostate. i kinda stumped on this one, im thinkin maybe could it have somthin to do with the fan sensors, maybe their not kicking on at the right temp?
Old 10-20-2009, 04:11 PM
poormillionaire2 poormillionaire2 is offline
Tune the PCM to turn the fans on at a lower temp, to match your t-stat.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 12-14-2009, 01:14 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Seriously? You say that like it's just an adjustment on a knob. Sure, while its a good idea from a performance mod standpoint, this is not good advice to fix this problem.
This is likely a failed temperature sending switch. Sounds like the swtich is kicking in at too high a temp. Either it is the wrong one for your car or failed. Replace it. There may be a coolant temperature sensor and a radiator fan switch seperately. sometimes they are the same sensor. I am not sure on 4th gens.
if that doesnt work, either replace the relay, or get an aftermarket fan switch/relay and wire it to your fan(s). Around $40 from summitracing.com
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 09-17-2010, 12:53 PM
skitch2 skitch2 is offline
My sone has a 96 and the temp will get up to about 230-240 before the fans kick on. I had a 91 before and it did the same thing. I called the dealer and they said that is the temp the fans are supose to come on at. so I think you are OK.
Old 09-17-2010, 05:21 PM
izzydjinn's Avatar
izzydjinn izzydjinn is offline
Did you purge the air out?
Is.... peanut butter jelly time, peanut butter jelly time, peanut butter jelly time, peanut butter jelly time.
Old 10-16-2010, 07:34 PM
kwoods5's Avatar
kwoods5 kwoods5 is offline
I recently had same issue with my 96 rs and mechanic determined there was an issue with the intake gasket. Sounded weird to me but after he replaced gasket it resolved issue and now my temp is about 210 at idle.
Old 01-13-2011, 12:22 AM
burned burned is offline
Could be a head gasket, or a plugged rad?
Some reading for you.
http://www.aa1car.com/library/overheat.htm
Old 03-16-2011, 12:12 AM
FastIROCZ28's Avatar
FastIROCZ28 FastIROCZ28 is offline
IraqIROCvet03
This is really about normal. The fans kicking on at those temps you stated and I'm assuming it's alot of stop and go traffic? Yes, this is about normal and my car does this almost too. My fan will kick on and keep her cool and she never overheats.
1988 IROC-Z28 Camaro 350 TPI Modified.
Stage 2 IROC in order; mildly built A4 Trans.
Highest speed - 150mph @ 5,600RPM's.
1/4 mile time in 03/09 before I began project on car was 14.0 @ 98mph @ Gateway International.
Best 0-60 was 4.9 seconds as of 01/2011.
Highest ticket so far: 75mph in a 45mph zone.
Best kill so far: LT1 Camaro Z28 in 02/2011.
