Old 10-19-2009, 02:10 AM
raymarquise raymarquise is offline
Exclamation Heater Blower works only on high
1994 Plymouth Voyager
My heater blower only works on high - it will not work at any other speed. After searching the forum, it seems the problem is the resistor block - which I would like to replace, if I can get some help in locating it.
So far in the forum, I have only seen the photos and descriptions for the Dodge Caravan. Has anyone got any photos of the location of the resistor block on the Voyager?? or a description of how to get to it to replace it??
ANY help would be greatly appreciated.
Thanks
Old 10-19-2009, 08:51 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Heater Blower works only on high
The only difference between a caravan and a voyager are the emblems and nameplates! Otherwise everything else is the same.
The resistor can be accessed in the engine compartment. It is bolted to the firewall on the passenger side. This is a 96 but gives you a pretty good idea of what your looking for.
make sure you check the harness/connector (if you can even get it off) for rust/corrosion.
Old 10-19-2009, 09:14 AM
Anil Khanna Anil Khanna is offline
How to Bleed breaks for caravan 2004
Old 10-19-2009, 10:00 AM
Airjer_'s Avatar
Start your own post!
Old 10-30-2009, 04:54 PM
Teddie Teddie is offline
Might be of help. I replaced my blower motor when it would only work on high.
