Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-18-2009, 07:54 PM
ripp_jr ripp_jr is offline
Question trans swap help
yes was wondering if a transmisson out of a 2003 impala will work in my 2001 impala both are 3.4 liters engine
Old 10-19-2009, 07:07 PM
HeMi101's Avatar
HeMi101 HeMi101 is offline
Send a message via AIM to HeMi101 Send a message via MSN to HeMi101 Send a message via Yahoo to HeMi101 Send a message via Skype™ to HeMi101
Re: trans swap help
They changed some things in 2003/2004. You would need a PCM from a 2003 and the engine wireing harness from a 2003 to use a 03 trans.
Old 10-25-2009, 10:34 PM
tractorboy's Avatar
tractorboy tractorboy is offline
Re: trans swap help
does the 04 still use the 4T65E
Old 10-26-2009, 09:28 AM
HeMi101's Avatar
Re: trans swap help
2000 - 2010 Impalas ALL use the 4T65E yes. Just over the years they improved/changed some minor stuff.
Old 11-11-2009, 05:01 PM
MNSubbie MNSubbie is offline
Re: trans swap help
Hey Ripp....I was wondering if you ever did your swap and if everything turned out OK??
I actually am going to try to just the opposite and put an 01 Tranny into an 03. Trying to find out if there is a way i can make my swap work----maybe its as simple as having the wiring harness and computer to match the transmission?? Any tips or feedback would be appreciated
Old 11-11-2009, 05:55 PM
wafrederick wafrederick is offline
Banned
Re: trans swap help
The PCM does not have to be changed and I put in a 2001 in a 2003 without changing the PCM.You have to make sure it is the right one and there are a couple things to look at the wiring plug,the big round plug looking for the color.For example a brown plug will not work with the vehicle coming with a green plug.The gear ratio has to be right or it will not work.The final drive can be swaped out to the replacement real easily.
