Old 10-18-2009, 05:32 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Turn signal stalk removal, GM steering column.
Can someone remind me if the stalk simply pulls out or if it unscrews.
It's a 1984 Jeep Cherokee which uses a typical 1980's-era General Motors steering column, The stalk has washer and wiper controls at the tip, but no cruise control.
A friend has accidentally snapped the old lever off. The remains of the broken shaft is flush with the housing, so I will have to drill it and use an easy-out or something to remove it.... unless someone has a better solution??
Thank you
Old 10-22-2009, 10:28 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Turn signal stalk removal, GM steering column.
I dunno, but if you can find the replacement part you can look at how it attaches to the column. My guess would be that it is held in there with a pin or set screw.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-24-2009, 02:08 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
most of those press in. drill a hole down the center of the remaining piece stuck. then take the back side of a cheap drill bit or tiny nail with some super glue on it and shove it in the hole you drilled. then just pull the broke piece out.
Old 10-24-2009, 04:27 PM
MagicRat's Avatar
thank you for the info.
