Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 10-18-2009, 03:47 PM
LieutenantCracker's Avatar
LieutenantCracker LieutenantCracker is offline
Is it OK/how to clean a Coill - on - Plug Ignition Coil?
Changing spark plugs. Ignition coils' dilectric grease / boot protector lube that I applied to the inside of the boot, last time I changed plugs, was discolored, smelled HORRIBLE, & was yellow-- a little dry... "Pasty". Appearing to possibly no longer possess luricating qualities.
1) Is this normal, or a sign of a problem?;
2) Just as a matter of semi-routine maintenance, even if the "pasty" problem wasn't an issue, is it OK to clean " Coil - on -Plug " ("C.O.P.") spring - coils / boots? If so, how?: Brake cleaner on spring-coil & soapy water & a small brush in/on rubber boot That's my guess(?)
________
IOLITE VAPORIZER COLORS
Old 10-18-2009, 04:34 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Is it OK/how to clean a Coill - on - Plug Ignition Coil?
The discoloration is normal. It should cause no problem. As far as cleaning the boots, anything that will not deteriorate the coil will work. Cleaning the spring can be completed with anything that will take the old grease and dirt off the spring.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-19-2009, 04:09 PM
Great-- I'll try all of that! Thanks, as usual, WTO!
________
Herbalaire review
