Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 10-18-2009, 10:56 AM
woodkanoe551 woodkanoe551 is offline
93 honda del sol door want open
have a 93 honda del sol. got out of car and closed door on seat belt in door. Now door will not open from the inside or the outside. Any suggestion? Can the door panel be removed from the inside with door closed? Thanks,
Old 10-18-2009, 02:06 PM
Wolf95 Wolf95 is offline
Re: 93 honda del sol door want open
Um, most likely it got caught in the latch. And i've never tried taking my panel off with the door closed but if you are desperate to get it done i'd at least try it.
Old 10-18-2009, 02:18 PM
seat belt is hanging half in and out of the bottom of the door
Old 02-06-2011, 12:21 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
You will likely need a friend to help you push in on the door while you try to unlatch it, the door panel is almost impossible to remove when closed and will likely destroy it. The pressure being put on the latch is preventing it from releasing.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
