Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 10-18-2009, 01:33 AM
bass_caster bass_caster is offline
trans filter/fluid change
00 tahoe nbs 4x4
i was considering changing the trans filter and fluid and replacing it with synthetic. any thoughts? any recommendations as far as brands go? also, how many time do i need to change it to get rid of all the old. the way i understand it, only about half of the fluid is drained when the pan is dropped. is that right? my last question, or maybe an assumption is that the synthetics are compatible with the real stuff and wont cause any issues when they eventually get mixed in a partial fluid change?? any help is appreciated.
Old 10-19-2009, 09:34 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: trans filter/fluid change
Originally Posted by bass_caster View Post
00 tahoe nbs 4x4
HOW MANY MILES ON IT?
Ever been serviced?
Is it giving you any problems?
GM does have a new synthetic fluid that they use to replace dexron 111.
But changing all fluid or going to synthetic at one time can/does stir up problems on a high mileage transmission.
Condsider age and mileage and transmission condition before changing over.
MT
Old 10-19-2009, 09:38 AM
MT-2500's Avatar
AF - Advisor
All DEXRONŽ-III licenses expired at the end of 2006 and will not be renewed. That's why you're seeing multi-use fluid.
Beyond that date GM will only support the use of DEXRONŽ-VI fluids for use in Hydra-Matic transmissions. Fluids sold in the market after that date bearing claims such as “suitable for use in DEXRONŽ-III applications” or similar wording should be avoided. DEXRONŽ-VI licensed fluids are fully backward compatible and can be used in all applications covered by earlier GM ATF specifications. The use of unlicensed fluids and/or non GM approved aftermarket additives may prove detrimental to transmission performance and void warranty coverage.
GM-approved brands of DEXRONŽ-VI * This list represents the companies who have conducted the appropriate testing and received GM approval. *Company name, license number, and brand name are shown.
DEXRONŽ-VI Service Fill Approved Fluids
Company***License Number***Trade Name
Advanced Lubrication Specialties*** ***
Allegheny Petroleum***J-60152***Altra DEXRONŽ-VI Transmission Fluid
American Agip Co. Inc.***J-60306 ***Agip DEXRONŽ-VI ATF
BP Lubricants USA, Inc.***J-60309 ***Castrol DEXRONŽ-VI ATF
Chevron Corporation***J-60005***Chevron ATF DEXRONŽ-VI
Chevron Corporation***J-60005***Havoline ATF DEXRONŽ-VI
Chevron Products Company***J-60308 ***Chevron ATF DEXRONŽ-VI
Chevron Products Company***J-60308 ***Havoline ATF DEXRONŽ-VI
Citgo Petroleum Corporation***J-60317 ***CITGO TRANSGARD DEXRONŽ-VI
ConocoPhillips***J-60004***ConocoPhillips Company DEXRONŽ-VI ATF
ConocoPhilips***J-60004***Kendall Motor Oil Company DEXRONŽ-VI ATF
ExxonMobil Corporation***J-60002***ExxonMobil IMP 6544
Fuchs Petrolub AG***J-60310 ***TITAN ATF 6000 SL
GMSPO***J-60301 ***GM Vehicle Care DEXRONŽ-VI ATF
GMSPO***J-60301 ***AC/Delco DEXRONŽ-VI ATF
Gulf Oil International***J-60304 ***Gulf DEXRONŽ-VI ATF
Gulf Oil International***J-60311 ***Gulf DEXRONŽ-VI ATF
Kuwait Petroleum***J-60314 ***Q8 Auto D VI
Lubricating Specialties Company***J-60322 ***Unitran DEXRONŽ-VI
Northland Products***J-60316 ***Northland DEXRONŽ-VI ATF
PDVSA Deltaven S.A.***J-60315 ***TRANSFLUIDO SINTEICO DVI
Penrite Oil Company Pty Limited***J-60302 ***Penrite ATF DX-VI
Penrite Oil Company Pty Limited***J-60312 ***Penrite ATF DX-VI
Petro-Canada Lubricants***J-60001***Petro-Canada DEXRONŽ-VI ATF
Pinnacle Oil, Inc.***J-60321***
Pinnacle Resources, Inc.***J-60320 ***
SK Corporation***J-60003***ZIC DEXRONŽ-VI
SOPUS Products***J-60307 ***
Valvoline***J-60151***Valvoline ATF DEXRONŽ-VI
Valvoline***J-60319***Valvoline ATF DEXRONŽ-VI
Valvoline (Australia) Pty Limited***J-60313 ***Valvoline ATF DEXRONŽ-VI
Warren Oil Company***J-60318***COASTAL DEXRONŽ-VI
Warren Oil Company***J-60318***WARREN DEXRONŽ-VI
Warren Oil Company***J-60318***LUBRIGUARD DEXRONŽ-VI
Warren Oil Company***J-60318***SERVICE PRO DEXRONŽ-VI
MT
Old 10-19-2009, 09:42 AM
MT-2500's Avatar
AF - Advisor
Here is some more to chew on, from GM, couldnt open the pdf for some reason, but here is the html version.* * http://209.85.165.104/search?q=cache...nk&cd=48&gl=us
This is the html version of the file http://www.gm.com/automotive/gmpower...ase_31MY07.doc.
G o o g l e automatically generates html versions of documents as we crawl the web.
To link to or bookmark this page, use the following url: http://www.google.com/search?q=cache...nk&cd=48&gl=us
Google is neither affiliated with the authors of this page nor responsible for its content.
These search terms have been highlighted: ***dexron ***vi
General Motors DEXRONŽ-VI Global Service-Fill Specification
During early 2005 General Motors released a newly developed automatic transmission fluid (ATF) for the factory fill of all GM Powertrain stepped gear automatic transmissions. The new fluid provides significantly improved performance in terms of friction durability, viscosity stability, aeration and foam control and oxidation resistance. In addition, the fluid has the potential to enable improved fuel economy and extended drain intervals. Since the performance of the new fluid far exceeded that of the DEXRONŽ-III service-fill fluids available at the time it became necessary to upgrade the DEXRONŽ service-fill specification in order to ensure that similar fluids were available in the market for service situations.* This latest upgrade to the service- fill specification is designated DEXRONŽ-VI.
Since General Motors introduced the first ATF service-fill specification in 1949 it has been periodically necessary to upgrade the specification. This upgrading process ensures that available service fill fluids are of an appropriate quality for use in transmissions that have been designed around the factory fill fluid performance. It should be noted that, as with previous upgrades, DEXRONŽ-VI fluids are designed to be backward compatible with earlier transmission hardware. More importantly, earlier type fluids are not forward compatible with transmission hardware that was designed to use DEXRONŽ-VI fluid, i.e. DEXRONŽ-III is not compatible with the most recently designed transmissions, and the use of these earlier type fluids could result in transmission damage. All current calibrations and certification tests are now conducted with DEXRONŽ-VI ATF. DEXRONŽ-III fluids should not be used for these applications where the owners manual recommends the use of DEXRONŽ-VI. GM does not license or support obsolete ATF specifications or the use of fluids that are being marketed against cancelled specifications.
All DEXRONŽ-III licenses expire at the end of 2006 and will not be renewed. Beyond that date GM will only support the use of DEXRONŽ-VI fluids for use in Hydra-Matic transmissions. Fluids sold in the market after that date bearing claims such as “suitable for use in DEXRONŽ-III applications” or similar wording should be avoided. DEXRONŽ-VI licensed fluids are fully backward compatible and can be used in all applications covered by earlier GM ATF specifications.
There is a published list of GM-approved brands of DEXRONŽ-VI (see page two of this release).* This list represents the companies who have conducted the appropriate testing and received GM approval.* Company name, license number, and brand name are shown.* This list will be updated on a regular basis as more approved products are added.
Company ***License Number ***Trade Name
Advanced Lubrication Specialties ***J-60155 ***Advantage DEXRONŽ-VI
Allegheny Petroleum ***J-60152 ***Altra DEXRONŽ-VI Transmission Fluid
American Agip Co. Inc. ***J-60306 ***Agip DEXRONŽ-VI ATF
BP Lubricants USA, Inc. ***J-60309 ***Castrol DEXRONŽ-VI ATF
CAM2 Oil Products ***J-60327 ***CAM2 Synthetic ATF DEXRONŽ-VI
CAM2 Oil Products ***J-60329 ***CAM2 Synthetic ATF DEXRONŽ-VI
Carquest ***J-60323 ***Carquest DEXRONŽ-VI Full Synthetic ATF
Chevron Corporation ***J-60005 ***Chevron ATF DEXRONŽ-VI
Chevron Corporation ***J-60005 ***Havoline ATF DEXRONŽ-VI
Chevron Products Company ***J-60308 ***Chevron ATF DEXRONŽ-VI
Chevron Products Company ***J-60308 ***Havoline ATF DEXRONŽ-VI
Citgo Petroleum Corporation ***J-60317 ***CITGO TRANSGARD DEXRONŽ-VI
ConocoPhillips ***J-60004 ***ConocoPhillips Company DEXRONŽ-VI ATF
ConocoPhilips ***J-60004 ***Kendall Motor Oil Company DEXRONŽ-VI ATF
ExxonMobil Corporation ***J-60002 ***ExxonMobil IMP 6544
ExxonMobil Corporation ***J-60002 ***Mobil DEXRONŽ-VI ATF
Fuchs Petrolub AG ***J-60310 ***TITAN ATF 6000 SL
GMSPO ***J-60301 ***GM Vehicle Care DEXRONŽ-VI ATF
GMSPO ***J-60301 ***AC/Delco DEXRONŽ-VI ATF
Gulf Oil International ***J-60304 ***Gulf DEXRONŽ-VI ATF
Gulf Oil International ***J-60311 ***Gulf DEXRONŽ-VI ATF
Hicks Oil Inc. ***J-60326 ***Formula 500
Kuwait Petroleum ***J-60314 ***Q8 Auto D VI
Lubricating Specialties Company ***J-60322 ***Unitran DEXRONŽ-VI
Morris Lubricants ***J-60324 ****
Northland Products ***J-60316 ***Northland DEXRONŽ-VI ATF
PDVSA Deltaven S.A. ***J-60315 ***TRANSFLUIDO SINTEICO DVI
Penrite Oil Company Pty Limited ***J-60302 ***Penrite ATF DX-VI
Penrite Oil Company Pty Limited ***J-60312 ***Penrite ATF DX-VI
Petro-Canada Lubricants ***J-60001 ***Petro-Canada DEXRONŽ-VI ATF
Pinnacle Oil, Inc. ***J-60321 ****
Pinnacle Resources, Inc. ***J-60320 ***Multipurpose DEXRONŽ-VI ATF
Schaeffer Manufacturing Company ***J-60325 ***Schaeffer DEXRONŽ-VI ATF
Shell Lubricants ***J-60307 ***A/C Delco DEXRONŽ-VI ATF
Shell Lubricants ***J-60307 ***Quaker State ATF DEXRONŽ-VI
Shell Lubricants ***J-60307 ***Pennzoil DEXRONŽ-VI
Shell Lubricants ***J-60154 ***A/C Delco DEXRONŽ-VI ATF
Shell Lubricants ***J-60154 ***Quaker State ATF DEXRONŽ-VI
Shell Lubricants ***J-60154 ***Pennzoil DEXRONŽ-VI
SK Corporation ***J-60003 ***ZIC DEXRONŽ-VI
Smitty's Supply ***J-60153 ***Super S
Smitty's Supply ***J-60153 ***Sure Guard
Superior Lubricants ***J-60328 ***Tuxton DEXRONŽ-VI ATF
Total Lubrifiants ***J-60330 ****
Valvoline ***J-60151 ***Valvoline ATF DEXRONŽ-VI
Valvoline ***J-60319 ***Valvoline ATF DEXRONŽ-VI
Valvoline (Australia) Pty Limited ***J-60313 ***Valvoline ATF DEXRONŽ-VI
Warren Oil Company ***J-60318 ***COASTAL DEXRONŽ-VI
Warren Oil Company ***J-60318 ***WARREN DEXRONŽ-VI
Warren Oil Company ***J-60318 ***LUBRIGUARD DEXRONŽ-VI
Warren Oil Company ***J-60318 ***SERVICE PRO DEXRONŽ-VI
MT
Old 10-19-2009, 05:38 PM
MT-2500's Avatar
AF - Advisor
Bulletin No.: 04-07-30-037D
Date: November 21, 2007
INFORMATION
Subject:
Release of DEXRON(R)-VI Automatic Transmission Fluid (ATF)
#Models
Attention: DEXRON(R)-VI Automatic Transmission Fluid (ATF) is the only approved fluid for warranty repairs for General Motors transmissions/transaxles requiring DEXRON(R)-III and/or prior DEXRON(R) transmission fluids.
Supercede:
This bulletin is being revised to update model/model year information. Please discard Corporate Bulletin Number 04-07-30-037C (Section 07 - Transmission/Transaxle).
MANUAL TRANSMISSIONS/TRANSFER CASES and POWER STEERING
The content of this bulletin does not apply to manual transmissions or transfer cases. Any vehicle that previously required DEXRON(R)-III for a manual transmission or transfer case should now use P/N 88861800. This fluid is labeled Manual Transmission and Transfer Case Fluid. Power Steering Systems should now use P/N 9985010 labeled Power Steering Fluid.
Consult the Owner's Manual or Service Information (SI) for fluid recommendations.
Some of our customers and/or General Motors dealerships/Saturn Retailers may have some concerns with DEXRON(R)-VI and DEXRON(R)-III Automatic Transmission Fluid (ATF) and transmission warranty claims. DEXRON(R)-VI is the only approved fluid for warranty repairs for General Motors transmissions/transaxles requiring DEXRON(R)-III and/or prior DEXRON(R) transmission fluids. Please remember that the clean oil reservoirs of the J 45096 - Flushing and Flow Tester machine should be purged of DEXRON(R)-III and filled with DEXRON(R)-VI for testing, flushing or filling General Motors transmissions/transaxles.
DEXRON(R)-VI can be used in any proportion in past model vehicles equipped with an automatic transmission/transaxle in place of DEXRON(R)-III (i.e. topping off the fluid in the event of a repair or fluid change). DEXRON(R)-VI is also compatible with any former version of DEXRON(R) for use in automatic transmissions/transaxles.
DEXRON(R)-VI ATF
General Motors Powertrain has upgraded to DEXRON(R)-VI ATF with the start of 2006 vehicle production.
Current and prior automatic transmission models that had used DEXRON(R)-III must now only use DEXRON(R)-VI.
All 2006 and future model transmissions that use DEXRON(R)-VI are to be serviced ONLY with DEXRON(R)-VI fluid.
MT
Old 10-19-2009, 06:05 PM
777stickman 777stickman is offline
MT: Great info and thanks...............777
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-19-2009, 08:15 PM
j cAT j cAT is offline
00 tahoe nbs 4x4
on my 2000 silverado the transmission was serviced with mobil synthetic transmission fluid , this was done in 2001.. the reason I did this was because I always replace the transmission fluid when the first 20,ooomi comes up..this synthetic made a big difference..fast shifting smoother shifting and less drag..better MPG..dexron III spec was stopped because it was an issue with these transmissions..I have had no issues ...now over 125,000mi, and replaced fluid about 4x..ALSO NO LEAKS.
the new dexron VI is supposed to be the fix ...and is a good fluid also..
replacing the fluid if it has not been done ever could cause problems,,as mentioned debris can get loosened and valves can stick..
do not get the flush treatment because this can stir up even more debris..
if you clean the drain pan , and install the correct high quaility filter, you should be good ,,the after a few thousands miles do it again ..that way it will all be synthetic and the debris will be removed..
with a 4X4 you have other drive train fluids that need servicing . have you replaced these fluids yet ?
Old 10-20-2009, 05:58 PM
my 'hoe now has 205,000. the original transmission crapped out and was replaced at about 165,000 miles on it. i was really disappointed since i was religious about getting the transmission, transfer case, and rear diff fluids changed at 30,000 mile intervals since i did a fair amount of towing my boat. each time i had the dealership do the full transmission flush. anyways, the new transmission has the remainder of the miles so thats a bout 40,000. i am thinking of just dropping the pan and changing the filter/fluid myself to save some cash.
Old 10-20-2009, 06:02 PM
2 follow ups...
what would be considered a quality filter... ac delco? purolator? something else? i dont mind paying a few bucks more if it does the job.
also, does the transfer case and rear diff fluids need to be changed as often as the trans fluid? if not, what would the mileage intervals be on that? and are synthetics better for those applications too?
Old 10-20-2009, 06:05 PM
what kind of probs can occur if the switch is made?
Old 10-20-2009, 06:24 PM
with this transmission since it was replaced you should go ahead and replace the fluids/filter as you did before/or do it youself..as mt2500 stated the dexron III was around up until the last few years...and as GM stated in its explaination of this change to the dexronVI the III was causing transmission failures of a very high rate...
the replacement of the other drivetrain fluids is good to do at 30-40,ooomi..since you will be driving in snow /ice the componets get used often ,,,hopefully this year we up here get a break for once..
the napa filter I got was the same exact filter that is the gm filter OEM...this filter had even the same plastic number /letter stamping and with the rubber gasket was 23.oo approx..much cheaper than dealer last time dealership was 50.oo++ for filter...
I have never flushed any transmission,,this can cause failures....if the fluid is contaminated then flushing would be necessary..like coolant got into it etc...
the other preferred method would be to replace all the fluid at the transmission cooler ..using these lines you can drain out the circulating fluid and then add into the dip stick tube what comes out until 12 quarts are used ..then you got it all replaced..
replacing the transmission fluid to the new dexron or the mobil synthetic tranny fluids will cause no problems...these are fully compatible ...just that these will work much better...after you do this change over let the forum know if you see any changes..
Old 10-28-2009, 01:46 AM
i bought a napa fileter the other day for about $27 w/tax, now i just need to get the fluid. i'm down to mobil 1 or royal purple, then i found something on the royal purple website that i thought was alarming... the tech tip at the bottom...
Max ATF is recommended in vehicles requiring any of these automatic transmission fluids:
  • Allison: C-4, TES-295, TES-389
  • Audi G-052-025-A2
  • BMW: LA2634, LT71141
  • Chrysler: ATF+, ATF+2, ATF+3, ATF+4
  • Ford: MERCON, MERCON V
  • GM 9986195
  • GM: DEXRON, DEXRON-II, DEXRON-IID, DEXRON-IIIG, DEXRON-IIIH
  • Honda ATF-Z1 (except in CVT's)
  • Hyundai: SP-II, SP-III
  • JWS 3309
  • Kia: SP-II, SP-III
  • MAN 339F
  • Mercedes Benz 236.x
  • Mitsubishi Diamond: SP-II, SP-III
  • Nissan: Matic-D, Matic-J, Matic-K
  • Subaru ATF-HP
  • Toyota: Type I, T-III, T-IV
  • Voith: 55.6335.3x (G607), H55.6336.3x (G1363)
  • Volvo: 97340 (Construction Equipment), 4-6 Speed AT
  • VW TL52162
  • ZF: TE-ML 14B, TE-ML 16L, TE-ML 17C
ť back
Please note: Max ATF is not recommended or an approved warranty replacement for: Aisin Warner AW-1, Ford Type F, Ford Mercon SP & Mercon LV, GM Dexron VI, Mercedes Benz MB 236.12 & 236.14, Shell M1375.4 (ZF 6-Speed AT) and Toyota WS. Max ATF is not recommended for use in any CVT applications.
so i guess i will be using mobil 1 after reading this info
