Old 10-18-2009, 01:26 AM
bass_caster bass_caster is offline
blazer fuel filter ?
OK...DUMB QUESTION TIME... where the heck is the fuel filter on my moms 99 blazer? i assumed it would be mounted on the inside of the frame rail like it is on my tahoe but its not down there. her fuel filter is overdue for a change. is it in the engine compartment? somewhere else?? also, is it the metal canister type or the pleated paper tpe? what should i look for and where? thanks
Old 10-18-2009, 09:55 AM
wafrederick wafrederick is offline
Banned
Re: blazer fuel filter ?
It is under the vehicle on the frame rail.I do have one tip,get a 20mm wrench instead of using a 13/16" wrench since it fits better on the fuel filterfitting.It is a metal canister.
Old 10-19-2009, 08:21 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
its on the driver's side frame rail (look under the driver's door). Its a metal canister held on by a black plastic clamp with fuel lines clipped into the top.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-20-2009, 06:06 PM
thanks guys, i'll have to take another look next time i stop by her place. i must have missed it. it sounds like the same set up as on my '00 tahoe.
Old 12-14-2009, 04:09 PM
lulou lulou is offline
I have a 95 Blazer w/ 4.3L Vortec, and it is inside the frame rail closer to the back on the drivers side, going out to change it right now. What are YOUR Symptoms to change it? Idling a little rough I hope? Runs fine otherwise?
Old 12-26-2009, 11:17 AM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
If she is over due for a new filter, I suggest that you go buy a new one from your favorite parts store, this will give you a good visual on what to look for and you will only have to crawl under the truck once.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
