Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 10-17-2009, 07:16 PM
oldkckr41's Avatar
oldkckr41 oldkckr41 is offline
05 malibu Maxx
My 05 maxx was in a recent accident air bags deployed and right front smashed pretty good no fluid loss just body damage It will crank but wont start doesn't sound like the fuel pump is running is there a shut off that cuts out the fuel after a hard hit?
Old 12-08-2009, 08:59 AM
dconger2010 dconger2010 is offline
Re: 05 malibu Maxx
have you replaced the fuel pump yet?
Old 12-09-2009, 07:28 AM
jyount jyount is offline
Re: 05 malibu Maxx
Hey how are you, I grew up in Potosi and live in Farmington now. Anyhow, yes the government mandates that there is something to shut the fuel off in a crash, started mandating it in the late 90s. It is usually an inertia relay that is probably in the trunk area, look at the manual, it will tell you all about it if its there.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 12-09-2009, 11:51 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 05 malibu Maxx
Not on a GM! Ford is the only one of the domestic manufacturers that has the inertia switch.
Old 12-09-2009, 04:35 PM
Re: 05 malibu Maxx
There has to be something, I'm pretty sure its govt mandate to have something
Current job: RN
Wife's
Old 12-10-2009, 10:53 AM
Airjer_'s Avatar
Re: 05 malibu Maxx
I do believe that GM uses the oil pressure switch to supply the fuel pump with power after the vehicle is started. It primes the system and gets the vehicle started with the relay and then shuts down the relay and allows the oil pressure switch to provide power. Once the engine stops the power to the pump stops.
Old 12-18-2009, 05:13 PM
oldkckr41's Avatar
Re: 05 malibu Maxx
Thanks guys I unplugged computer and battery then put a full charge on it and it started still have a emission light on and need to replace my clock spring body work done and airbags or done thanks again
