Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-17-2009, 05:01 PM
racinrus racinrus is offline
04 wheel hub
do i need any special tools to remove wheel hub for 04 1500 2 wheel drive
Old 10-20-2009, 08:40 PM
badchallenger09's Avatar
badchallenger09 badchallenger09 is offline
Re: 04 wheel hub
Probably just a big socket, 1 1/2 maybe. Not positive on the size but I believe that's about it. Maybe some snapring pliers, I can't recall for sure, it's been a while since I did them.
Old 10-20-2009, 08:51 PM
wafrederick wafrederick is offline
Banned
Re: 04 wheel hub
If it is the wheel bearing assambly,you are going to have a heck of a time getting it out thanks to Chrysler.Chrysler set the tolerances way too tight in the spindle including the wheelbearing in the 4x4s.
Old 10-21-2009, 10:02 PM
troy1 troy1 is offline
AF -Advisor
Re: 04 wheel hub
^^^^ That I will agree with those are a mother ^^^^
Old 10-26-2009, 10:22 AM
Jim Ramstad Jim Ramstad is offline
Re: 04 wheel hub
Actually the hubs will fall right out with just a few taps with a hammer in the right spots. Worst part is the drive shaft splines but they are no worse than any GM Vehicle I have worked on.
Old 10-27-2009, 05:50 PM
Banned
Re: 04 wheel hub
2004s and up are this way and will not come out.Had one 2004 4x4 with this problem ,wheel bearing will not come on both sides
Old 10-29-2009, 04:50 PM
thejacobhartman thejacobhartman is offline
Re: 04 wheel hub
i had to do both on mine and the best way i found was to grind down a cheap chisel and pound it between the hub and spindle around the edge. a friend at a dealer suggested a smooth craftsman driver because whe it breaks through the handle from hitting it with a hammer, you can return it and do it again.
Old 10-30-2009, 12:13 AM
RahX RahX is offline
Re: 04 wheel hub
We use a bar propped between the hub and the frame. Start the truck up and turn it so the bar pushes the hub out using power steering pressure Works wonders if it is a stubborn one.
