Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-17-2009, 01:39 PM
fp1529 fp1529 is offline
Water leak behind blower motor?
1999 1500 Suburban. I just found water leaking from behind the what I believe is the blower motor under passenger side floor board. I can press up on the bottom of it and water pours out. I took the plastic guard off under the windshield wipers. When I spray water on the right side it flows out from under the fender and also under the dash. Any help would be appreciated
Old 10-17-2009, 01:54 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Water leak behind blower motor?
Maybe a plugged evap drain. You should see the outlet on the firewall, passenger side of the engine compartment, From underneath.
Old 10-17-2009, 02:02 PM
Is the evap drain the same thing as the AC condensation tube that runs just under heater hoses, it is a 90 degree tube??
Old 10-18-2009, 04:36 PM
ronaldk's Avatar
ronaldk ronaldk is offline
A clog in evap tube will allow condensation to build up inside pass compartment, but when you spray water from outside your veh it should not be able to come in. I would think you have a rust through area in firewall. Try using extension mirror and light to locate. Then you can try to silicon or seam seal closed. Good luck
Old 10-26-2009, 09:46 AM
grumpy5 grumpy5 is offline
Check the sealant around the fresh air intake. I had the same problem. You may have to remove the grill below the wipers on the passenger side and the valance panel wher the glove box is to see it.
