Old 10-17-2009, 10:17 AM
engineering2009 engineering2009 is offline
Please Complete this Quick Survey
For an engineering project, I need to do some preliminary research. I would really appreciate it if you took a few short minutes to do this survey. Thank you !
If you change your own oil:
How often do you do it?
Do you think changing oil is messier than it needs to be?
Have you ever:
1. Dropped the bolt into the waste oil pan or onto the ground?
2. Not been able to find the bolt after it had been dropped?
3. Gotten hot oil on yourself?
Are there any other problems you have had when changing the oil in your car?
If you do not change your own oil:
Why do you take your car somewhere else to get the oil changed?
Thank you !
Old 10-17-2009, 11:37 AM
Mavrick14 Mavrick14 is offline
Re: Please Complete this Quick Survey
Have you ever:
Yes
No
Yes
No
A) its convenient, price is only a couple dollars more (if that) when compared to buying your own parts, dont have to worry about disposing of your old oil filters and oil, usually get fluid top ups etc.
Thank you !
Licensed Mechanic
Old 10-18-2009, 07:55 AM
534BC 534BC is offline
Hi, welcome to Automotive forums.
How often do you do it? Every 1-2 years
Do you think changing oil is messier than it needs to be? No
Have you ever:
1. Dropped the bolt into the waste oil pan or onto the ground? Yes
2. Not been able to find the bolt after it had been dropped? No
3. Gotten hot oil on yourself? Yes
Are there any other problems you have had when changing the oil in your car? Yes
Thank you ![/quote]
