Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-17-2009, 03:05 AM
rochm rochm is offline
Idle issues
I have a 94 Eclispe 1.8l, 5spd, it runs good, but sometimes when you are in gear or not the rpms vary between 1200 - 400 and then go back up. Then sometimes when you are driving and start to come to a stop and as you down shift rpms drop to 0 and it will stall. It will do this in neutral sometimes but not all. I hope you can give me an idea where to start. Thanks
Old 10-17-2009, 07:08 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Idel issues
I would check the ISC/IAC motor, that does all of your idle adjusting and even when you let off the gas it provides enough air to keep running. In the Haynes/Chilton manual they show how to test the coils in the ISC/IAC, you just need an ohm meter to do so, check it and see what you get.
Old 10-17-2009, 10:12 AM
Re: Idel issues
Ok thanks I will check it . Thanks
Old 10-18-2009, 11:27 AM
ned032002's Avatar
Re: Idle issues
Let us know how it goes, idle issues are very common so let us know.
