Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 10-16-2009, 11:58 PM
jadafi jadafi is offline
drive shaft?
99 sierra 4.8 - "clunking" coming from rear end when put into gear ... also does it when shifting at low speed .....u joint? ANYBODY????
Old 12-02-2009, 11:02 AM
ebedsilva ebedsilva is offline
Re: drive shaft?
I too get a clunk when I put the tranny in gear. If its like a whinning noise when your moving more than likely its a u joint. With a jack pick up the back diff lifting the tires off the ground, chock ur front tires and put in drive letting the tires spin freely. You'll see if its the u joints.
2001 Sierra SLT Ext Cab Z71
2000 Malibu LS
Old 12-02-2009, 08:59 PM
Re: drive shaft?
............. so what will the joint do if it does need replacing ? , what should I be looking for ? I appreciate the advice , but getting under the truck while the tires are spinning with the truck truck running sounds a little dangerous , but I'll do it anyways .... probably .
Old 12-03-2009, 05:18 PM
pies pies is offline
Re: drive shaft?
known problem with gm trucks. gm fix is to pull out drive shaft and put some special grease in the slip spline. they did this to my truck and the clunking was gone.
