Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-16-2009, 10:21 PM
fax fax is offline
2005 Bonneville GXP Torque Specs
I will be replacing both front wheel hub bearings and can not find the axle nut torque, I found the torques for the SE & SLE, but not the GXP. Any ideas?
Thank you
Old 10-17-2009, 10:44 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 2005 Bonneville GXP Torque Specs
GXP has the same hub bearing as the SE & SLE, so use the same specs. BTW, best to use use a new lock-nut if the hub bearing you get does not have one included. Usually, ACDelco comes with the lock-nut & hub bolts.
