Old 04-07-2003, 02:16 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
amp
has anyone ever heard anything about this amp? If its any good or not. And i'm not sure if its too big for my subs or not. The reason im asking is that my buddy is sellin his for cheap. I dont need five channels but might as well get it for the price. Could sumone tell me if this amp is too big for two 12"JL W0's, their rated at 125 watts rms, i dunno what the max wattage is. http://mobileaudio.boom.ru/pictures/...mps/kac859.htm
thnx
Old 04-07-2003, 02:21 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
well i don't know how the 5 channel thing is going to work out, never messed with an amp with 5 channels. But your subs will be able to handle it. I had 2 12" w0's that were getting about 250 watts each with no problem. I don't know exactly what they were getting, never had that tested, but I had a 120 watt @ 4ohm load Planet Audio amp running at a 2 ohm load and pushing those subs no problem.
Wish I could offer a little more help with the amp, but don't know much about 5 channel amps. Seems more like a normal speaker amp, not a sub amp.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 04-07-2003, 02:24 PM
alright thats good to know its not too big, but i still dunno bout the five channels, like the specs are tellin me it puts out 240 wattsx2
Old 04-07-2003, 02:26 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
i don't think you should get it. It's supposed to be you use 4 channels for your coaxial/component speakers and the one dedicated channel for your sub. how much is it going for, i didn't see a price on the site. If you want a decent amp, get a Kenwood 729S amp...they're 100x2 4 ohm stereo and they are alright units. I had one powering 1 pioneer sub and it got the job done, then i got an audiobahn sub and it was lacking so i decided to go with an audiobahn amp and 1 more sub
Empty Pockets Racing Member #1
Old 04-07-2003, 02:27 PM
alright thats good to know its not too big, but i still dunno bout the five channels, like here are the specs
Power Ratings
Bridged Power Output at 14.4V (1kHz, 0.8% THD): 120 Watts x 2
Maximum Output Power (Bridged): 240 Watts x 2 + 240 Watts x 1
Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 60 Watts x 4 + 150 Watts x 1 (at 100Hz)
Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 40 Watts x 4 + 120 Watts x 1 (20Hz - 200Hz)
Old 04-07-2003, 02:29 PM
so u thnkt that a 2 channel or 4 channel would be best. Hes sellin it for 100 to 150$ canadian.
Old 04-07-2003, 02:30 PM
GScivic7's Avatar
the only thing i don't get is if that 1 sub channel acts as like a mono block so that it can handle 2 ohms mono or what...so confusing
Old 04-07-2003, 02:31 PM
GScivic7's Avatar
you don't even need a 4 channel, if you just want to power your subs get a 2 channel amp
BTW are those JL's DVC or SVC?
im lost with amps so im clueless
Old 04-07-2003, 02:36 PM
GScivic7's Avatar
i think the W0's are SVC, so look for an amp that is about 125 x 2 watts rms at 4 ohms like this would be perfecthttp://www.ikesound.com/1024.htm
EDIT: damn the link doesn't take you straight there...anyways, go to pioneer and look for the GMX-972 amp. BTW When you click on pioneer if it asks if you want to d/l some language pack just click cancel
Old 04-07-2003, 03:31 PM
Tony's Avatar
TLD Member #1
yea, a 2 channel amp will do just fine for 1-2 Single Voice Coil Subs. When you look for an amp for them, look at the bridged X 1 rating. Around 300 X 1 @ 4 ohms will be good for those SVC subs, or 500 X 1 @ 2 ohms, because the amp will be running at a 2 ohm load if you hook the subs up in parellel.
Tony
Old 04-07-2003, 05:29 PM
im not sure if their svc or dvc, arnt they dvc if theres two positives and two negitevs on each sub? Cause thats what they have. So what size od amp should i look for like between 300 and 600?
Old 04-07-2003, 09:31 PM
Tony's Avatar
TLD Member #1
Yes, a DVC sub has 2 + and 2 -. mine was just a SVC, so yours should be able to handle more than mine did. So you probably need to get a 4 channel amp for both of the subs.
Tony
Old 04-07-2003, 09:50 PM
OneSikCRX OneSikCRX is offline
Send a message via AIM to OneSikCRX Send a message via Yahoo to OneSikCRX
and dont be fooled by the dvc and svc thing, dvc subs, no matter what anyone else sais are not(not by themselves anyway) twice as loud as a svc sub, yes they are a little louder and can handle more power, but they were designed for lower impedences, and to make it easier to wire different combinations and still be able to get the ohms you want
Old 04-07-2003, 09:57 PM
Tony's Avatar
TLD Member #1
oh god, the whole DVC is twice as loud as a SVC is haunting me, damn everyone took that the wrong way. I did not mean that a DVC IS TWICE AS LOUD AS A SVC, i meant that it was almost twice as loud, mainly because of the reasons you stated, because you can more easily mess with the combination of wiring it.
Tony
