Old 10-15-2009, 07:00 PM
shenning shenning is offline
Driver Side Door Window
I've spent a lot of time recently wrestling with the driver's side door window in my '99 Grand Prix GT (K version). It works for a few days, then sticks fully closed. I've taken out the regulator and motor. Both seem to work okay when disconnected from the window. I've lubed the regulator, window tracks, and replaced the window switch. I'm beginning to think that the motor may be breaking down under load. Any thoughts?
Old 10-15-2009, 10:36 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Driver Side Door Window
Your probably on the right track with a motor issue.
Old 10-16-2009, 01:21 AM
doctorhrdware doctorhrdware is offline
Also it is possible for the switches to have a problem too. My passenger front door window stopped opening for quite a long time. Then out of the blue starting working again. I took out the switch assy and sprayed the switches with electrowash. Then used Craig labs deoxit on the switch contacts and had no more problems. I did all four of the switches.
Old 10-16-2009, 06:24 PM
I've replaced the switch with a new one, so I think it's okay. I'm looking for a reasonably priced reliable window regulator and motor. Does anyone have any suggestions?
Old 10-16-2009, 11:37 PM
Airjer_'s Avatar
We have had really good luck with the dorman brand.
Old 10-17-2009, 03:21 PM
That's the brand I've been looking at. It's good to hear that someone has had a positive experience with Dorman.
Thanks!
Old 10-17-2009, 09:01 PM
Airjer_'s Avatar
They make a lot of good products and only a few that are questionable.
Old 10-18-2009, 11:23 PM
darkcherrymetallic darkcherrymetallic is offline
I've had the same problems that you are having. At first I bought some replacement parts from ebay because it was half the price compared to parts from an auto part store, but the parts from ebay only lasted me two and a half weeks before it died on me. I eventually got some Dormans from Autozone and it's been fine since July.
Old 10-19-2009, 06:13 AM
Thanks for the feedback, everyone.
Old 10-25-2009, 04:23 PM
CraigZerch CraigZerch is offline
Go with the oem pontiac parts, but dont buy directly from your dealership if you want a deal. If you buy oem you know you are getting a good part.
Old 10-25-2009, 07:51 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
the oem part is what just failed you. how is that a good part? when something fails me common sense tells me to try something else
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-25-2009, 08:38 PM
I bought one from fleabay for the wife's truck. The window was stuck down during last winter. That one was better then the OEM one that I bought and installed 2 summers ago. Which was driver's side window that I replaced. The fleabay one is much faster and stronger then the OEM. The passenger side I also replaced with an OEM and now it will not open all the way. It will open maybe 1/4 and starts to make a grinding noise like the gears are slipping. So I will stay away from the OEM replacement window regulators. Quality is crap and you do not get what you pay for.
Old 10-26-2009, 01:31 PM
I have to say that I normally stay away from non-OEM parts, but I took a chance on the Dorman window regulator and motor. It took me less than an hour to remove the old one, install the new and button everything back up. Of course, I've had soooooo much practice working on this thing now that I can probably due it in my sleep! Anyway, the new regulator and motor work very well. Let's see how they hold up.
Old 10-26-2009, 01:42 PM
I usually do to, using OEM parts too. Doing the window in the wife's truck it only took me about 45 minutes give or take a few. It is second nature now. I still have to do the passenger side window I think I will order from the same place that I ordered the driver's side door. It was with free shipping. It will not take me that long to do. I use the blue painters masking tape to hold the window up. That way I do not worry about the window falling down and shattering. The driver's side it holding up very well. I am very pleased with the performance and reliability.
Old 10-27-2009, 08:44 PM
I'm thinking about doing the passenger side regulator and motor too. It's already pretty slow. With winter coming, I don't want it to stop altogether - especially in the down position.
