Go Back   Automotive Forums Car Chat > Buick > Century
Old 10-15-2009, 05:42 PM
chscole010 chscole010 is offline
rear running lights and dash lights stopped working
rear running lights and dash lights on my 95 buick century stopped working I checked all the fuses and they're all good can anyone help me out?
Old 10-15-2009, 10:40 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: rear running lights and dash lights stopped working
If the front running lights also don't work (2 side markers and two park lights) than I would check to see that there is power at the brown wire from the headlight switch.
Old 10-16-2009, 08:31 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
If the front lights work and the high mount brake light works, you probably have a bad turn signal/mulitfunction switch. Pretty common issue
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-16-2009, 11:34 PM
Airjer_'s Avatar
I think this still gas the old style turn signal switch. The only thing it would inhibit is the brake lights or turn signals if it where bad. It would not disable the running/parking lights.
Old 10-18-2009, 06:45 PM
thanks for the posts. the problem has been solved. i think that it was just a little loose wire harness hahaha because i went to unclip it in the trunk to check if the brown wire was getting power and as soon as i started playing with it, my running lights and dash lights both just turned on like nothin was ever wrong. thanks for the input
