Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-15-2009, 03:08 PM
headscratching headscratching is offline
Dex Cool Fool
I own a 99 Sl2 and whoever sold it to me must have flushed it and replaced the coolant with good ole green antifreeze...this is fine, however I did not know this, I guess i could have looked in the reservoir and seen it but i didnt, anyways my coolant level was low so I went to napa they told me i need dex cool so i bought it and topped off my coolant and in doing so mixed the two different coolants....now i have sludge.
MY problem is I need to flush my system completely block and all but do not know how to do so because this car has no normal radiator cap, only a overflow reservoir with a cap...so how do I properly flush this system, i can do it myself i just need a little input...do i need to remove the thermostat? what hose if any should i splce the T valve into and where should the flush water come out of while im flushing...thanks to any that can help.
Old 10-15-2009, 03:38 PM
RC1488 RC1488 is offline
Re: Dex Cool Fool
Radiator draining:
http://www.youtube.com/watch?v=eSji7N5ommg
Block Draining:
http://www.youtube.com/watch?v=JEoLFrg8IUI
Coolant flush procedure:
"If you are just talking about maintenance and you aren't doing something like cleaning up an engine that's had a cracked head or something. Just draining and filling is fine. However, that's not what you're asking about. Here's how to do it.
  • Drain the coolant as you normally would.
  • Remove the thermostat and replace the housing.
  • Remove the return hose going to the top of the coolant reservoir and run it to something to catch coolant.
  • Get a bucket of hot water mixed with automatic dish washing detergent and fill the coolant system from the bucket.
  • Have someone start the car and as the coolant system drains into the container, keep filling it from the bucket.
  • Do this till it runs clear.
  • Next run clear water through the system until it's clear of detergent.
  • Run a couple gallons of distilled water though.
  • Replace the thermostat.
  • Reattach the return hose at the top of the coolant reservoir.
  • Fill with 50/50 mix of ant-freeze and distilled water." - Barnowl
I'd also clean the reservoir while your at it.
Next time get the Universal Coolant that can mix with anything.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 10-15-2009, 07:55 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: Dex Cool Fool
Mixing Dex-Cool with regular coolant does NOT magically instantly create sludge. The belief that it does is just a myth. Any sludge that you are observing was there before you mixed coolants. If you mix Dex-Cool with regular coolant, treat it like regular coolant. Flush/refill the cooling system within 2 yrs/30,000 miles (like you're supposed to with the green stuff anyways) and you'll be fine.
In any case.....follow RC1488's recommendation for the flush to rid of your sludge. I would strongly recommend using a long-life coolant (particularly Peak extended life universal coolant) because it behaves with aluminum better than the regular old green coolant.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 10-19-2009, 05:12 PM
Cat Fuzz Cat Fuzz is offline
Re: Dex Cool Fool
Yeah, what they said ^^
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
