Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 10-15-2009, 11:14 AM
CAMFLIGHTRN CAMFLIGHTRN is offline
2001 Expedition P0308
Started running rough a couple days ago, today got a flashing CEL then on my way to Autozone, engine became increasingly rough. Pulled code "P0308 cylinder 8 misfire."
I plan on pulling the plug, checking, the wire and coil.
Any additional help would be appreciated.
which one is cylinder #8 (I'm assuming it is the hardest to get to)
5.4 Triton
Old 10-15-2009, 12:07 PM
wafrederick wafrederick is offline
Banned
Re: 2001 Expedition P0308
It is on the driver's side,the back one and it is a pain to get to thanks to Ford's bad engineering.The #8 coil is bad since it has the Coil over Plug ignition system and could need a tune up at the same.Most parts stores stock the coils since they do go bad.
Old 10-15-2009, 12:43 PM
thanks, just pulled the plug and yes it was a pain to get to. The plug electrode is almost gone and the gap was at 0.70. I'm on way to pick up plugs, if that doesn't fix it I'll try replacing the coil.
Thanks
Old 10-15-2009, 02:22 PM
Banned
Replace the #8 coil too,I agree with them being a pain.If there is a hard way to do things,Ford has it.
Old 10-16-2009, 10:07 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Just switch the coil with another cylinder. If the misfire has moved to the cylinder you swapped coils with, replace that, too. Otherwise don't fix it if it ain't broken. And IF you do get a new one, use only Motorcraft coils. The Accels and other off brands at Autozone and online do not last very well.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
