Old 04-07-2003, 12:58 PM
sragona34 sragona34 is offline
Question Installing Halo projector lights.. NEED HELP!
I just purchased a set of Halo projector lights for my 95 civic.. and the instructions (if thats what u want to call them) are terrible. Thay dont tell u how to do anything. My question is, does anyone know how to install these with all of the wires that are given?
On the headlights, there are 4 wires, 2 white and 2 read, then there is a separte set of wires that have a mess of plugs on them..
Need help desperately, thanks.
Old 04-07-2003, 01:33 PM
GhettoLegs's Avatar
GhettoLegs GhettoLegs is offline
Send a message via AIM to GhettoLegs Send a message via Yahoo to GhettoLegs
From the sound of it.. you are mostly concerned w/ the wiring... so that's what I will explain. If you need help w/ the main installation, just ask.
Okay... first of all... those 4 wires (2 red, 2 white) are for the actual halos. One set is for the low beam halo and one is for the high beam halo. You are gonna wanna run the red power wires through the fender wall and tap into the parking light wire for your corner lights. Make sure that it is the wire for the parking light filiment... the one that stays on when you turn your parking lights on... not the one that flashes. This way, when you turn your parking lights on, your halos will turn on also. Ground the black wires or run them to the negative stream of your parking lamps.
Here, I used speaker wire and connected both reds to one positive wire and both blacks to one negative wire.
Old 04-07-2003, 01:36 PM
GhettoLegs's Avatar
Here I ran the wire through the hole in the engine bay to the fender... then to the wiring harness for the parking lights.
Old 04-07-2003, 01:42 PM
GhettoLegs's Avatar
Now.... your the new projector lights will plug right into your original headlight harness. They are black plugs like those shown in my picture. Unplug the original headlights from these and plug in the new ones.
Old 04-07-2003, 01:46 PM
GhettoLegs's Avatar
After you plug the harness together... you need to mount the relays to the inside of your engine bay walls to ground them. Just find a place that's easy to get to and won't get in the way of anything else. Simple.
Here's the relays mounted to the passenger side wall in my car:
Old 04-07-2003, 01:51 PM
GhettoLegs's Avatar
Then just run the 2 remaining wires up to your positive battery post... don't forget to put the fuses in. 1 for low beam, 1 for high.
Old 07-18-2008, 04:10 PM
drivetothedirt drivetothedirt is offline
Send a message via AIM to drivetothedirt
Re: Installing Halo projector lights.. NEED HELP!
i have 2 questions....when u reffer to the black wires are u reffering to the white wires?
and where did u get the relays from...with mine if u plug the aftermarket lights into the stock harnesses there are no relays.....my relays came on another set of wires with several harnesses/plugs
help would be appreciated
Old 07-19-2008, 06:35 PM
n/m figured it out
Old 09-30-2008, 05:13 PM
Sentient Sentient is offline
I own a set of led/halo projectors for a 2008 civic, the lights come with harness plugs for the high beam and headlight and also 2 sets of black and white wires with now plugs for the halos and led's, how do I wire up the 2 sets of black and white wires for the halos and led's, and where would i find the wires to tap into
Old 02-21-2009, 10:16 PM
jamesnlcc1 jamesnlcc1 is offline
I can't seem to open any of the pics... any advice?
Old 03-25-2009, 07:16 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Check the post dates, its super old... AF probably deleted the pics off their servers after a set period of time.
AF's Official Asshole
RIP AUNIE
Old 04-19-2009, 11:37 AM
near87 near87 is offline
yeah.. the pictures would come handy now.. too bad!
Old 05-26-2009, 09:58 AM
simav simav is offline
Need Projector Installation Help 2003 Camry
Okay, anyone please help me if you can..
here is the situation:
i bought some projector halo headlights off of eBay for my 2003 Camry, and when i got the lights, i tried to install them, the item said no modifications necessary, so when i tried to put them on, the fitment was off..when i say fitment i mean that the main top bolt part wont reach where its supposed to on the car body, and even the bottom snap on part is even off from where its supposed to go onto the car....i hope i didn't waste any money, i think i did..are these fake headlights? or is there something else that i am supposed to do..
Thanks...
