Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 10-14-2009, 04:21 PM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
Ac issues
My inlaws car is a 2002 or 03 ford focus, and they were having issues with the ac/heat. it would only blow on the highest setting (4). so they took it to a shop and they replaced the blower motor resistor. Then a few months later the problem is back. I saw some people with the same issue, and most linked back to the resistor, so i'm going to replace it this time. i know its behind the glovebox, but i have never worked on a ford, just on hondas. so i was wondering if anyone had a manual or some help on how to get to it. does the glovebox just pull out like a honda's would? and can i get to it like that, or will i need to remove the dash? any help would be grateful. thanks
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
Old 10-23-2009, 06:24 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Re: Ac issues
just stick your head under there, there might be a carpet panel with a couple of push pins holding it. but you dont need to remove anything, its right there. and if you're chewing through resistors, you might make sure youre not getting water in the blower case.
Old 10-26-2009, 08:53 PM
outofstep's Avatar
Re: Ac issues
ok i got into it, but not too sure what im looking for. anyone have a pic showing the part im gonna be changing?
90 civic:
JDM d15b
CAI
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
eibach sportline
CF SIR hood
Old 10-29-2009, 08:08 PM
Re: Ac issues
lets try to uploaad this pic....it should be this connector to the left of the motor, has 4-5 wires going to it. kinda a square-ish connector, rectangular part... umm...as long as I've been a member, how do you upload a pic stored on my desktop? I found a decent one from ford's technician site..
Old 06-01-2011, 09:49 AM
NYranger NYranger is offline
Re: Ac issues
this is what happened to my wife's car.Water got there(when it is heavy rain it always leaks heavy inside) but this time it did burn something there and when C is on then you put fan to full,AC shuts off.Does anyone know how expensive it is to fix this problem? As for the leak,I have no idea how the water gets there...
Old 06-01-2011, 12:36 PM
Re: Ac issues
Ok.Fixed it.Bought the part- 35 bucks on Staten Island- from the stealer But fixed it and that's all to it.Man I am happy.At the shop they would take it probably like 100 bucks or so.
