Old 10-14-2009, 09:40 AM
Mom2boyzz Mom2boyzz is offline
99 Windstar- going through coolant
Hi guys!
So... continuing problems with the Windstar... Shocking, I know!
I'm going through TONS of coolant...
Thinking it was the head gasket, we did an oil change & tested the oil to see if there was coolant in there... No coolant in the oil.. oil was ok.
NOW...
I've got white smoke when I start it up in the morning (not all the time, only when started up cold when it's been sitting all night)
It's also dripping from the exhaust pipe... quite a bit too.. there's a good puddle under the tailpipe & you can see it drip every 2 seconds or so.
We put some Bars stop leak stuff in there last night, it says on the can it can plug head gasket leaks & cracked blocks...
Now, since the van is a 99 and has 174,000km on it, I'm looking for a replacement, as I can't go more than a month or two anymore without a problem.
My question primarily is....
Will this Bars stop leak stuff help solve the problem, at least for a little while?
Is this for sure a cracked block... is there a way to find out exactly what it is without spending much more $, or ripping it apart
How much time do I have before it will quit, if at all?
Thanks again for all your help, you guys have been great!!
Old 10-14-2009, 10:52 AM
12Ounce 12Ounce is offline
Re: 99 Windstar- going through coolant
Normally the leaks are something other than blocks and head gaskets ... if you are sure that the coolant is making its way into the exhaust, I would suspect the lower intake gaskets and seals ... they can be very difficult to get "right". Took me a couple of times.
But it is a dangerous situation ... if you get enough coolant into a cyl, this can leak to locking up a piston and destroying the engine.
