Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 10-14-2009, 06:16 AM
Meridivs's Avatar
Meridivs Meridivs is offline
Lightbulb 2 3.1 Pontiacs, different electrical behaviour
Hello fellow Trans Sporters!
We have recently acquired our second 3.1 Pontiac ('91) and, beside the temperature gauge starting from 1/4 up there's another very interesting electrical issue:
- if you take the battery + cable off with the motor running the motor shuts down immediately
On our '92 Pontiac TS with the same 3.1 engine the motor keeps running when I took the + cable off.
Does anybody knows why this happens? Any idea would be greatly appreciated.
Old 10-14-2009, 08:35 AM
LMP's Avatar
LMP LMP is offline
Re: 2 3.1 Pontiacs, different electrical behaviour
Originally Posted by Meridivs View Post
....if you take the battery + cable off with the motor running the motor shuts down immediately.
I would not risk that. The battery is an efficient voltage damper and even with a voltage regulator in the alternator, a voltage spike at battery disconnect is highly possible and it has happened that it blew one or several electronics components. I've seen it again at a friend's place last summer.
THe way different regulators behave might explain what you describe...in addition, rectified voltage from the alternator is supplied by a series of voltage pulses that can turn off to zero in between and the alternator looses excitation..and this can depend on the number and type of accessories in operation .
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
