Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 10-13-2009, 07:43 PM
windryder windryder is offline
Battery and OverHeating?
My 2001 LS 3.9L overheated about 2months ago. it pegged the temp gauge, and the reduced power light came on. I pulled over and let it cool about 5-10minutes.When I started it again the gauge was at the halfway mark, where it is normally.
Thinking it might be the hyd.fan, I got on the interstate and drove at 70-75mph hoping the fast air flow would keep it cool. It did for a couple of miles,then started gettin hot again, but would cool down on its own.
Ever since then it would get hot about twice a week, no matter where or how I was driving.Now it gets hot about every time I drive it! I tryed it with or without the A/C. No change, it seemed to get hot when it wanted to!
I found that when it showed that it was hot, I could pull over turn it off wait a second then restart it. The gauge would go to the half way mark, and all seemed ok. Sometimes it would remain cool, and sometimes it would show hot again, and I would pull over and restart again.
It acted like the thermostat wasn't opening, but as soon as I restarted it it would cool down!
After reading one of the posts in this forum about how over loaded the electic system is in these cars I started wondering if the battery could be causing false sensor readings!
Someone had installed a smaller 400CCA 500CA battery instead of the larger battery that it should have.(650-750CCA). Idid a load test on the small battery and it dropped like a rock!
I bought the right battery, which was hard to find, and installed it. I also checked the ground connections, and the main pos. to the fuse box, and cleaned the terminals.
It's been 3 days since I installed the right battery, and it hasn't gotten hot once!
I never would have thought the battery might be why the car was overheating! But so far It hasn't gotten hot. I will keep you updated as I drive the car more..
Old 10-13-2009, 09:27 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Battery and OverHeating?
As sporadic as the gauge was acting, the weak battery may have been playing games with the coolant temperature sensor circuit.
Interesting post, keep us updated as you get a few more miles in.
-Rod
Old 05-15-2012, 01:03 AM
Update: After about 3 months the overheating problem returned. I replaced the de-gas bottle, installed an after market electric fan and control, and found a cheap OEM New cooling fan, and installed it. I power washed the radiator, and A/C evaporator. The electric fan helped somewhat, but on real hot days it overheated. Great car for the winter, but I parked it all summer.
I was ready to sell the LS as scrap!I really think I would have, but my parents had given me the car, so I only had the cost of the parts invested.Plus I had to solve this problem or go crazy.
About the only part I didn't change was the fan pump, but I was looking for one! I found that the pump was controlled by an Actuator! I bought the actuator(which is a bitch to install), and it fixed the problem. After 3 years of hell the LS is finally driveable again. I have put a couple of thousand miles on it so far, and it's doing great. I hope this will help someone before they start throwing parts at their LS. The actuator cost me $130..
Old 05-15-2012, 07:54 AM
shorod's Avatar
SHO No Mo
Wow, that's good information. Thank you for following-up with a long-term update! Very glad you got it fixed.
-Rod
Old 05-15-2012, 10:13 AM
danielsatur danielsatur is offline
The early LS had problems with both the thermostat + water pump impeller.
Once you weed out all the problems you can change the name to MKZ!
Thanks for the follow -up &, don't forget about the salvage yards for cheap parts.
Old 05-15-2012, 01:41 PM
shorod's Avatar
SHO No Mo
Well, there's very little commonality between the LS and the MKZ....
-Rod
Old 06-26-2012, 04:56 PM
Jasongruven Jasongruven is offline
I am having the same problem in my 01 LS! Can u explain where the actuator is located, and where u found a new one.
Jason
Old 06-26-2012, 05:25 PM
Lightbulb Re: Battery and OverHeating?
LS died & MKZ took it's place!
May Crown vic, LS, T-bird, and Windstar rest in peace.
