Old 04-07-2003, 12:30 PM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
car is swaying like crazy
before i had my camber kit installed my car stuck good around turns but now that the camber is installed the thing sways like crazy. i have a strut bar in the back but none in the front. would a strut bar cure that problem?? i don't like the feel of it at all. i can tell i would get into a accident easily if i was going fast and i had to swerve for some reason, i know i would lose control. any advice would be appreciated.
Old 04-07-2003, 12:33 PM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
front strut bar might help.. also look into getting some thicker sway bars for the front and rear
that should help, also a lil negtive camber isnt too bad for cornering
Old 04-07-2003, 12:44 PM
SiZ's Avatar
SiZ SiZ is offline
A strut bar won't affect body roll.
"The nympho of info, I'm fuckin' what ya heard"
Old 04-07-2003, 12:46 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I'm pretty sure u need an alignment.
Old 04-07-2003, 12:49 PM
tanas's Avatar
tanas tanas is offline
Send a message via AIM to tanas
what do you mena by swaying?
if you mean body roll, or tilting to the side when going around a corner, then you may need stronger struts/shocks
if you mean a slight shaking side to side then a strut tower bar and other supports to stiffen up the body might help
if you mean shaking up and down, or forward and back, then you might have brake shudder and warped rotors
please explain cause there could be many causes and many solutions.
-J
Apprenticing on the downhill
Learning to be a mechanic
Trying not to spin the car again before I can powerslide
Old 04-07-2003, 02:14 PM
darolh darolh is offline
No.
I assume you lowered the car too. Did you have the toe checked (front and rear). That being off would make the car nervous under cornering.
Old 04-07-2003, 02:20 PM
i had the car lowered with neuspeed race springs and it still handled great. then when i put the camber kit on it got all fucked up. its almost like it floats and has body roll. i don't like it at all. its hard to keep control of. it has something to do with that camber kit.
Old 04-07-2003, 02:26 PM
mellowboy's Avatar
Yeh then try adj. ur camber.
Old 04-07-2003, 02:29 PM
check your upper balljoints/get the camber adjusted right and go get the car aligned
that should take care of it
Old 04-07-2003, 02:50 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
get ur alignment checked it could be off causing it to do a push/pull kinda thing
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 04-07-2003, 03:58 PM
tanas's Avatar
why would changing the camber effect body roll? I would think there would have to be a problem somewhere else that didn't show up because of the way the wheels were oriented.
-J
Old 04-07-2003, 04:04 PM
do you think this would do the job?? and i had a alignment job done when the camber kit was put on. http://cgi.ebay.com/ebaymotors/ws/eB...category=33591
Old 04-07-2003, 04:07 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
This might be pointless and stupid, but here it is.
I had a pair of Goodyear Eagle GAs on the front. When I got the second set several months later, I had them move the front wheels to the back, and put the new tires on the front. The car handled great before I got there, and when I left, it had all of the disquieting traits you described. If I swerved into another lane on the highway, the car wanted to do an extra swerve after I was finished. I drove it to work once, cursing the whole way.
Once I got there, I put the slightly used tires back where they had been for 17,000 miles, on the front, and moved the new ones to the rear. Worked fine, and that's the way I've left it.
No, I did not have the directional orientation wrong.
So: did you change which tires/wheels were on the front when you had this work done?
Flunky
Old 04-07-2003, 04:11 PM
AF Premium User
PS-
I looked at the item you described. It's primarily intended to keep your wheels from jumping up and down during the kind of accelleration you only get while drag racing a fwd car with SERIOUS power. I don't think your problem can be helped by a strut bar of any sort. I'm betting something is out of adjustment in your suspension somewhere.
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
It could be a tire pull, but you would have noticed that prior to the alignment. Before you put the camber kit on you had negative camber which to a certain point will help the car to corner, now when it was aligned with the camber kit they probally put it to like -0.5 degree of camber, which will affect the cornering a bit by putting it back into the stock range. The body roll, i have no explanation for, get bigger swaybars.
