Old 10-13-2009, 02:18 PM
chris99taurus chris99taurus is offline
1999 radio replacment question
I have a 1999 ford taurus It has a radio with no cassette player I was wondering if it would be possible to change out with a factory radio with one that has a cassette
Old 10-13-2009, 08:06 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1999 radio replacment question
Shouldn't be a problem as long as you don't get one for the Mach system. I'm not sure the standard tape player would have the proper connections for the Mach system. I'm assuming you want a stock system with a tape player rather than an aftermarket system. If you want aftermarket, then you will need an adapter plate for the instrument cluster and a bypass harness for the Rear Control Unit (RCU) in the trunk.
-Rod
Old 10-20-2009, 02:22 AM
Stanger90 Stanger90 is offline
Use crutchfield.com to find out what you need to do the install. Excellent info on that site, and there stuff usually comes with great directions for installation.
