2007 Suburban LTZ Gas Mileage
I just bought a 2007 Suburban LTZ with the 5.3L Flex Fuel engine.
It has 20" tires. I am only getting 15 mpg on the highway and 13 mpg around town. I know the mpg is not great on these big trucks but that seems a little low. Is there any adjustments or after market things I can buy or use to help out with the mpg a little? Thanks in advance. LK |
Re: 2007 Suburban LTZ Gas Mileage
With the tire change the 1st thing is to check the accuracy of your odometer/speedometer. If it's running slow you're registering less miles than actual.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
I've checked the odometer/speedometer against my other car.
They are pretty accurate. Any other ideas? Thanks LK |
Flex fuel was even worse high 11's to low 12's ![]() I'm gonna check the plugs and change all the wet fluids since I'm now the 2nd owner and this will give me a base line. -Slyder |
Other than making sure that all is normal with your engine and filters, you might try a Hypertech Max Energy ECON # 33000 programmer. It is supposed to get you 2-4 more mpg and more power. Some even report up to 6 mpg increase. I am going to order one but haven't yet. Here is the cheapest one that I have found. Link
When I get one, I will report back with the results. |
I have an '07 3LT with the 5.3 and was getting similar mileage. Recently my transfer case crapped out. They replaced it under warranty and suddenly I was getting 2mpg better all around. So the numbers you're seeing now is what I get with E85. I get 17(H) and 15(C) with regular. Still not the advertised mpg for this rig, but it seems that the transfer case was causing some undue friction and apparently bad transfer cases are notorious for these rigs. Mine gave no warning that it was getting bad.
OSUCowboy27, I am interested to see if anything changed after you got the
ECON programmer. I've also found that the mileage is better when I use gas from out in the country instead of around St. Louis where they have a billion additives in the gas. Thanks every one for the feedback. LK |
I haven't yet received the programmer but it is on order.
Let us know! I have a feeling that if it's that easy and it works, GM would have already make this program standard factory equipment. Maybe it messes up emissions? |
