Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-12-2009, 11:38 PM
Eric007 Eric007 is offline
Ac/ Heat problem
no cool Air when when turn on Ac same as heater no hot air
Old 10-13-2009, 11:21 AM
Copytech99 Copytech99 is offline
Re: Ac/ Heat problem
Need more info on the car.
Is the fan blowing any air ??
Old 10-13-2009, 12:18 PM
350GT 350GT is offline
Yup what Copytech said, more infor please. Im not gonna make a judgement call so im just assuming that it might just be the blower resisitor possibly located near the pasenger side near the foot area.
But since there is not air blowing in, there must be a clog of some sort or the AC/Heater unit is defective
heres a website that allows you to get a better view of how the resistors looks like http://hondapartsnow.com
hope this helps
Old 10-13-2009, 08:54 PM
its a 99 Honda the fan blow air but no cold air and heater the same blow air but its not hot
Old 10-14-2009, 06:49 AM
It could one of the internal doors/flaps is not working to allow air to flow properly. Could be a challenge.
Old 10-14-2009, 11:28 AM
would it possibly be the heater/ac unit. Because that controls switching on and off of the ac/heater. I think its located near the passenger side foot well
Old 10-14-2009, 10:29 PM
this happen after an accident hitting a dear few months ago! any suggestion?
Old 10-14-2009, 10:36 PM
jd-autotech jd-autotech is offline
is ther enough coolant in it?
Old 10-15-2009, 01:49 AM
yeah there is coolant im not sure its leak or not but i fill it more...
Old 10-15-2009, 06:53 AM
You should try to locate the control/valve that allows coolant to flow into the heater core. It may be located out in the engine bay near the firewall. If you can locate the 2 coolant lines going in/out it should easy to locate the valve. With the car on and 2 people have someone work the the hot/cold setting back and forth from inside while someone watches the valve's operation to see if it is moving.
Is this a manual lever or pushbutton selection type system ??
Old 10-19-2009, 10:02 PM
Metal_Crue Metal_Crue is offline
Send a message via AIM to Metal_Crue
Check the A/C unit, mine has a crack in it, and my car won't blow warm air, either, but I think that's a problem with the thermostat
Old 10-21-2009, 12:31 PM
After hitting a dear. How fast were you going? Any fluids leaking?? Would it be a blower resistor?? Clogs wouldnt really be the issue, since your getting air, but not Cold or Hot.
Old 11-07-2009, 06:49 PM
i found out that the radiator and the intercooler fan are not spining maybe that cause the problem? do i need to get a new one or nething cus i might take to shop this weekend
Old 11-08-2009, 10:17 AM
Those fans are not required to have heat (they would be needed for A/C) The system may not be opening the mentioned valve allowing water into the heater core or one of the doors inside the dash is not working and blocking the heat from the core.
Old 11-08-2009, 07:06 PM
oh i see, i thought the cooler fan to keep the engine cool,but i drove around few tme not trusted to drive far..without the fans working can i be driveable or it can cause overheat anything?
