| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
96 2.4 starter
can some help i need to know how many and what color wires are going to the starter.? i know the red from the batt. but cant rembember the other ones and how many. thanks for any help you can give.
Re: 96 2.4 srarter
There should be another red cable that goes from the B+ terminal to the fuse box.
Some have the alternator connected to the B+ terminal at the starter as well, this is usually a blue fuseable link that disappears into that black protective stuff. The exciter wire goes to the "S" terminal (if labeled), is usually purple in color.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
