Old 04-07-2003, 12:29 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
Question Look!! how do i solve rusted headers???
Is their any type of spray or solvent that I can use for these rediculusly rusted header. They are 5 month old Heedman Headers. I don't know how they alreadly look so unsightly....Please Help!
Old 04-07-2003, 12:57 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Navel jelly might work what are the headers made of?
Old 04-07-2003, 07:31 PM
94civic's Avatar
94civic 94civic is offline
i had the same header and it did the same thing to me so i fixed it with a engine swap and there you go no more rusty piece of shit chikara header. what you can try to do is go to autozone and get that dupont high temp engine paint made to withstand 1200 degrees and sand the header off with some 300 grit then 600 grit and paint it.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 04-07-2003, 08:18 PM
HatchbackHoney's Avatar
HatchbackHoney HatchbackHoney is offline
Sandblast them then coat em with high temp paint or something
Old 04-07-2003, 08:40 PM
zippeay zippeay is offline
Buy a stainless header, even high temp paint will come off, headers dissapate a lot of heat even more than high temp paint can handle. That's really your only choice or you can rap it with that high temp insulation for headers, that would work too
Old 04-09-2003, 10:31 PM
jeffseby's Avatar
ok, thanks you guys, the headers are just the most basic header, i dont know what they are made of, $120 from summit racing.com, only ones i could afourd, otherwise i would get DC Sports or something.
Old 04-12-2003, 01:59 AM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
I would get rid of that shit and get DC like mine I got for 220 shipped.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 04-13-2003, 06:21 PM
jeffseby's Avatar
damn, that bay does look GOOD.
Old 04-16-2003, 10:19 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
In this case it might not be a bad idea just to get some "Header Wrap" and put-on it. At least it would hide the rust, and you would not have to worry about it rusting out, because it has already started....
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 04-16-2003, 11:45 AM
jeffseby's Avatar
i was thinking about header wrap, but dont you have to take out the headers to aply the wrap? I might just put my header heat sheild back on.
Old 04-18-2003, 02:12 AM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
Frontbyte: What kind of hp gains do you think you got from those DC's? Anything noticable?
Old 04-18-2003, 09:08 AM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
How you gonna put a heatshield on an aftermarket heeader?
Old 04-19-2003, 05:50 PM
luti luti is offline
Send a message via AIM to luti
Um, heat sheild and header wrap are very different. One is a piece of sheet metal, the other is a flexible metal wrap that goes around the headers. The only problem with it is that it can cause headers to crack since they don't allow the heat to disipate.
T3/T04E turbocharged ricer.
Old 04-19-2003, 10:37 PM
B16EJ1's Avatar
I know that. I didn't ask " what's the difference? ". I asked how can you put a heatshield on an aftermarket Headman Header?
Not possible. Maybe he meant put the oem header and heatshield.
Old 04-20-2003, 08:24 PM
jeffseby's Avatar
sorry, I don't know what I was thinking when I talked about putting a heat sheild on AfterMarket headers, I will try and fabricate some kind of thing to put on them to direct the heat to a certain position. OR SOMETHING.
