Old 10-12-2009, 11:50 AM
skbello1 skbello1 is offline
Unhappy a/t system malfunction.....HELP!
I just got a used 2003 honda civic hybrid cvt. the engine check light just came on and the "D" keeps blinking.also, the ima has gone crazy. the diagnosis read "70-02 a/t system malfunction"...please what's wrong, someone help me.
Old 10-12-2009, 12:57 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: a/t system malfunction.....HELP!
Since the check engine light (CEL) is illuminated, there is at least one current diagnostic code. You need to connect a scan tool and pull the diagnostic code(s). That will be step 1 in diagnosing the issue.
For specifics on what might be causing the IMA to "go crazy" you should consider moving your thread to the Civic specific forum. Are you referring to the IMA display in the dash, or the whole integrated motor assist system?
-Rod
Old 10-13-2009, 10:07 AM
hello,
i took it to the mechanics and the code was "70-02 a/t system malfunction". and once the D starts blinking (after some few meters), the ima doesnt work and the "ima" light comes on. my mechanic doesnt seem to know the code "translation".
please help out
thanks,
SKB
