Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-12-2009, 03:52 AM
jjk_52 jjk_52 is offline
just got a 1990 240 need help!
hi i just got my 1990 240sx and i have a little problem.when im in fourth and fifth gear the car seems to cut out at around four thaousand rpm.the motor doesnt die it just bogs out real bad and o have to push in the cluth and ghive it a rev thaen it fine again for awhile. i was told by the guy i gotr it from to change the ecu so i did but it didnt help.....PLZ help me out i an really new to this car!!!
Old 10-13-2009, 08:46 AM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: just got a 1990 240 need help!
If i remember correctly, I had a similar issue with my 240, and it turned out to me one of the vac lines to the intake.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 10-13-2009, 06:38 PM
the car cane with the original air box gone and a cone filter for a replacment. so should i look for the original box?
Old 10-19-2009, 08:56 PM
slideways...'s Avatar
slideways... slideways... is offline
iirc they all had fuel cuts at 4k in 4th and 5th? ecu programming.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 10-19-2009, 09:06 PM
RaeRae1's Avatar
RaeRae1 RaeRae1 is offline
Send a message via AIM to RaeRae1
No don't worry about getting an original air box, the aftermarket cold air intake should not be what is causing your problem.
Blessed are the cracked ones, for they are the ones that let in the light.
Originally Posted by 72chevelleOhio
Your cheer-mobile needs a flat tire.
Old 10-20-2009, 11:59 AM
so should i go abd get my ECU re-flashed?
