Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-11-2009, 07:34 PM
jr70895 jr70895 is offline
99 Ram 1500..What color antifreeze to use?
I am old school and it confuses me with the differant color anti-freeze/coolant that is being used and why
This is a 1999 model ram 1500 V-8 and not sure what color should be used and if it really makes a differant in that older model. For years I have always used the same green colored Prestone, however several people are telling me I am using the wrong color for Dodge...confused
Thanks
Old 10-11-2009, 08:56 PM
crazys182003's Avatar
crazys182003 crazys182003 is offline
Re: 99 Ram 1500..What color antifreeze to use?
It all depends on your preference anymore. I have a 2001 RAM 1500 318. Dodge uses a red color from the factory. Yellow can be added to either red or green. When my radiator crapped out on me I took it to my local dealer and had them pump it clean and put Green in since it is a lot easier to get in case of an emergency. If you decided to use either green or red just make sure you don't mix them. and I also keep a nice 50/50 mix.
Old 10-13-2009, 02:33 PM
bratt bratt is offline
I always get the 50/50 mix. Auto zone told me it doesn't matter what color you use and any color is fine.
I know Oil Stop in California said you have to use the right color that the manufacturer states.
People say different things. It gets confusing
Old 10-14-2009, 11:01 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I'm using the "mix with anything-easily available" yellow from Advance Auto although I suspect it's at all the chain type auto parts stores.
Old 10-20-2009, 08:18 PM
badchallenger09's Avatar
badchallenger09 badchallenger09 is offline
In my opinion, you are much better off flushing the red stuff out. In time it will eat away any and all gaskets it comes in contact with. The stuff is bad news and highly corrosive. I think the only reason it gets put in from the factory is for job security. They figure most people will take the vehicle to the dealership to have it worked on, so why not make their visits more frequent with gasket problems... right after the warranty is up. Use the green stuff, it's tried and true and was engineered to stop corrosion.
