Old 04-07-2003, 12:15 PM
CivicSkater CivicSkater is offline
Banned
Camber Kit
I'm gonna put coilovers on my accord, and im gonna drop it like 3 or 4 inches. And i was wondering, are camber kits easy to put on, like could i do it myself? If so, does anybody have a link to a site with instructions. Also, i saw a site that had instructions on putting on coilovers, and i lost it, does anybody know the site? Thanks.
Old 04-07-2003, 01:20 PM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
the anchor bolt ones are prety easy to put on. it took me less that 30 minutes to do my both sides.
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 04-07-2003, 09:52 PM
strodda strodda is offline
be careful when adjusting camber, dont correct totally. keep it somewhere between 1-2 negative degrees. i only dropped 2" and when i corrected to 0 deg. the arm hit on every bump. and the more extreme you drop the easier itll hit.
Old 04-08-2003, 11:05 AM
dutchaccord dutchaccord is offline
AND IF U DARE U CAN DO THIS:
DIY CAMBERKIT
It's still working great, but becareful,
Stefan
1 st........2nd........3rd
====== ==== == [[ ] ] H22A
Upcomming: Porche 964 brake swap
In progres: Boostin the H22
Old 04-08-2003, 12:19 PM
Banned
Should i get it installed proffesionally? Cuz i dont wanna screw it up, and i dont really have anybody to help me out. Will it cost a lot to get it done professionally, or should i try doing it myself?
Old 04-08-2003, 12:45 PM
install it ur self,then get ur car alighned at a tyre centre. Then ur set.
Stefan
Old 04-08-2003, 02:27 PM
i like strfan's idea. i was thining about banging the lower crossbone, that way the wheel won't rub the fender, but i got the anchor bolts and now i have to do the inner fender mod to get rid of the bangs from the arm.
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
Old 04-08-2003, 04:36 PM
Banned
Aight, thanks for the idea, thats definetly what im gonna do.
Old 04-08-2003, 04:38 PM
Banned
Hey strfan, is that a brake light at the top of your rear window, i cant tell. Oh ya, didnt you make that little thing hangin down your self? I think i remember that....
Old 04-09-2003, 12:44 PM
Yes (i had a roofspoiler w 3rd brakelight
And
Yes (little thing hanging? )
MORE PIC'S of all my DIY'S
roospoiler
camberkit
etc
etc
http://www.dawebcity.com/leden/dutchaccord
click the tab FOTOALBUMS
Stefan
Old 04-13-2003, 03:17 PM
Duatone Duatone is offline
after you put on a camber kit on ALL 4th GENS, its gonna take morethan a "little banging" to stop your a-arm from hitting. you actually have to cut out a good chunk of metal from the top of your fender well to give enough clearance for your a-arm to protrude through, otherwise, and ive seen this happen, if you let it go, and let it hit all the time, you WILL brake your a-arm.
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 04-15-2003, 09:33 PM
Banned
Duatone, are there any walkthroughs to show me what you mean. Cuz i dont wanna drop my car and end up screwin everything else. I dont quite understand what you are saying.
Old 04-18-2003, 06:36 PM
Its easier to figure out than you think. and sorry, i donth ave a camera or id take some pics, i think my vid cam can plug into my computer though, i'll check. anyways. heres the general idea. open your hood, stand in front of one of your wheels, and look down, as if your looking directly at your a-arm, hopefully you know what an a-arm is? anyways, obviously you cant see it, so you need to get a plasma cutter, or in the average joes case, a cutting wheel. preferably not a dremal, youd be doing it for days that way. you need to cut a hole big enough for your a-arm to go through. not the whole a-arm, mainly just where the ball joint is. you only need the hole to be big enough for your circumstances. the bad thing, it looks tacky to have these holes when you have your hood open. but, alas, there isnt another way around it, just a 4th gen prob. ive seen the hole wrapped with rubber trim and it looks pretty good, ive also seen a fabbed piece of plexi installed. see, mine poke out about 1/2-3/4" above that hole. it also sucks cause if your really low, your a-arm can go high enough to start hitting your hood, which mine has a small dent where it started to hit, i think, so i raised it a hair. anyways, i'll see what i can do for pics, till then, good luck finding anything, chances ar probably slim, and i'll do what i can to help you out. seriously though, its your only choice, unless you do air-ride.
so far:
1990 accord ex
Old 04-18-2003, 10:11 PM
93accordEX 93accordEX is offline
www.cb7tuner.com
Old 04-19-2003, 10:55 AM
how about welding a something over it ????
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
