During heavy rains when there is 1-2 inch water on the road, my PA (91) begins to make a weird noise. It is very loud, the first time I thought the exhaust must have broke off or something. It is a resonating, rumbling low sound which changes pitch with revs and speed.
I figured it must be the serpentine belt slipping, as the sound stops shortly after you get to dry road. But today I coincidentally parked the car and revved the engine, and there was nothing out of the ordinary. What could it be? Note this only happens during heavy rain with 1 inch of rain on the road, never during "normal" wet roads..
Re: weird noise while driving through heavy rain
Next time you experience this noise. Shift it down 1 or 2 gears and hold the same speed. If the noise changes, it's engine related.
If it's the same, maybe it's the tires.
65 Plymouth Belvedere 69 Dodge Super Bee 87 Dodge Ram 93 Ford Mustang 5L 00 Buick Park Avenue |
Thanks, do you have a part number for that ? The Goodyear parts finder doesn't know the ACDelco #.
Check AutoZone for the Goodyear Gatorback belt to fit your engine.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Thanks. It gives 2 Gatorbacks for the 91 base: the "Poly V (102,5")" and the "Poly-V alt & P/S (60,5")" but my PA only has 1 belt?
Also I've read somewhere that I should replace the idler and tensioner pulleys as well while changing the belt (is it correct that they are the same part according to Autozone?) (edit) I just checked and my PA does not have an idler pulley ! Also the parts store here says the pulley on the tensioner can't be replaced, though I see it held in place by a 15mm? bolt. Last edited by ZiggyPA; 10-14-2009 at 06:52 AM. |
