Old 10-11-2009, 01:31 PM
dhughins's Avatar
dhughins dhughins is offline
where do i get a new brake line for a 2000 silverado?
i broke the line that runs across the rearend from the t on the driver side to the passenger wheel. it's steel and wrapped with coils around it. autozone said to check with the dealer, as today is sunday will have to wait. has any of ya'll had to buy 1?
Old 10-11-2009, 10:36 PM
cramer_77 cramer_77 is offline
Re: where do i get a new brake line for a 2000 silverado?
your best bet would be just to buy a piece of bulk brake line from the parts store and bend it yourself to put it in. Dealership your gonna pay out the ying yang for a pre-bent line. Your only looking at 10-15 dollars for that line at a parts store plus brake fluid for when you bleed them. another line to check on while your looking at brakes lines is the one that goes from the front to the rear that goes between the gas tank and frame rail. I have replaced those more times than i can count. Pretty sure your truck uses 3/16ths line someone correct me if im wrong.
01 Silverado 2500HD, HID lows and highs, cold air kit, leveling kit, brush guard, dual flowmaster outlaw mufflers, 5% windows.
Old 10-12-2009, 11:59 AM
intimadatorsquizz intimadatorsquizz is offline
you can't buy that line from the dealer.you'll have to have it made my them or just make it yourself.don't worry about that coiled wire around it you can't get that anyway.it protects the line from rubbing thru.if the new one you makes rubs anything just slit a piece of hose and slip it on the area it will rub.
Old 10-12-2009, 12:54 PM
kahjdh's Avatar
kahjdh kahjdh is offline
3/16ths across the axle and 1/4 form the abs to the flex line. If you have never flared a line its prob a good idea to let somebody else handle it.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 10-12-2009, 06:36 PM
dhughins's Avatar
thanks. i'm bending it now and gonna have to try and put it on tomorrow if it will stop raining.
Old 05-26-2010, 10:24 AM
xxxyyyzzz xxxyyyzzz is offline
You can watch a video on eHow.com that shows you how to do all the brake lines step by step and how to cut, flare, splice, any brake line. EXCELLENT. This site is EXCELLENT too.
Old 05-26-2010, 01:07 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As said forget the coil stuff on outside of line.
Auto Zone or any good parts places should have steel brake line already made up in different sizes and lengths and fittings .
Take yours off and match up to right size and length and fittings and just bend to fit.
They make a bending tool to bend the sharp bends.
MT
