1999 Limina Axle Nut
Hello,
I'm getting ready to change the bearing and hub assembly on the drivers side front and I see an axle nut that has to come off. Does anyone know the size of the nut? I have to go buy the socket. Thanks, WOD288 |
Re: 1999 Limina Axle Nut
36mm
you will also need a big torx key (I don't remember the size but this one
was the biggest in the row of 10) and a good lever to undo the bolts that hold the brakes assembly. And don't forget about the C-clamp to free the rotors by squeezing the brake cylinders. Plus, you'll need a puller to remove the wheel hub assembly. In addition, I'd recommend keeping the old wheel hub assembly. The problem is that there's some probability that the new one can be slightly off-specs (I had this luck recently with one e-bay seller who had 20000+ positive rating). |
