Coolant on serpentine belt
2001 Windstar -
I have a coolant leak somewhere and it is getting on the serpentine belt and spraying everything. It is spraying droplets not streams of coolant. Makes me think it is a steady drip from somewhere, but I can't find it. Where are the most likely places for the leak? I've tried to follow the hose out of the overflow, but everything is wet already. Thanks!!! |
Re: Coolant on serpentine belt
If your engine is anything like mine (3.8L), there's a coolant pipe coming off the lower intake manifold which turns back towards the firewall. It then connects to a hose and goes to the water pump. That hose is directly over the belt, that would be my prime suspect.
If you have a pin hole leak you'll have to let the engine reach operating temperature, then pop the hood (being carefull not to get burned or stained by coolant) and then look for signs of steam or smell and fluid running around the belt. Sometimes when you shut off the engine at operating temp the leak will make a hissing or whisle sound like a tea kettle!
---------------------------------------------- Current Rides: 2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4 ________________________________________ Past Rides: 2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI 2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI 1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL ---------------------------------------------- |
Ed makes a good point......when you turn off the engine when it is warm......the temperature increases due to the fact that the coolant is not circulating......which should increase the pressure in the system.......possibly giving you the chance to see the leak in action.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
I've looked at it cold, hot and inbetween but I just can't seem to find the spot. Once the fluid starts to flow, the belt becomes wet and starts to spray droplets all over the engine on that side so it gets real wet. I guess it's just a spot that I can't see even with the mirror I'm using. The pipe that I am most suspecting is the one that comes out of the water pump. Because it goes back out of sight, I'm thinking that somewhere back there it must have a leak. I can see some corrosion where it branches off, so maybe right behind that spot? Anyone know how tough it is to get that pipe off and out of there? It seems awfully tight back there.
2000 Windstar SE 3.8L 125k miles (mine) ![]() 2006 Hyundai Sonata LX 3.3L 108k miles (wife's) ![]() 2013 Hyundai Elantra GLS 21k miles (daughter)
you could also get a pressure tester and pump up the rad to ~15lbs. That may just cause the fluid to escape from the leaky spot. I've found leaks in coolant this way.
----------- 2000 windstar 3.8 2010 honda pilot touring Muskoka Canada |
The tube is held on the water pump with one small bolt and with another one, where the tube become a "Y". Price at Ford dealership is between 35 and 40 dollars if I can remember, and I am not sure you can find it aftermarket ( Autozone, Advance etc).
2001 Windstar 2007 Pontiac G5 2004 Freestar 1999 Ranger |
So how long did it take you to replace the pipe? I have plenty of PB to soak on it for a day. I think I'm just going to go for it. Wait, how do I get the pipe at Ford, I mean what do I ask for so that they will know what I am asking for?
I just recently had a coolant leak in my 2000 Windstar, in the same general area that you're talking about. At first, I thought it was the water bypass tube - the metal tube that runs under the intake plenum - but it turned out to be the hose that runs from that tube to the reservoir. Basically, the hose got hard, the clamp could no longer hold the seal, and it broke it's seal... At first, it was a very definite spray; after I moved it a little, it became more of a mist.
It's something to look at. I got the part for 8 bucks; plus 4 bucks for a couple of new hose clamps, it's inexpensive and easy to replace, if you are in doubt. But for me, after I had moved it a little and it became a spray, once the engine warmed up a bit it would seal up again. You had to watch it from the time you started the engine with a flashlight or shop light to see the leak. |
I replaced the tube. Thanks for all the help on that. With the cowl off, it was fairly easy. BUT the problem has not stopped! The tube had a bad spot and was leaking, but I guess there is another leak! augh! I am suspecting the water pump. Is this a common failure?
My water pump is ten years old.
Replacing the water pump (at least on the older windstars) requires you to raise the motor a couple of inches......disconnect a motor mount.....and raise it up.....so that the pulley can clear the unibody frame member that is next to the pulley.
Ugh! raising the engine does not sound like fun. I hate to start this one not knowing that it is the answer. But, the coolant is definitely being sprayed by the moving water pump pulley. I just can't see how it is getting on that pulley!
