Old 04-07-2003, 11:03 AM
bender bender is offline
Change distributor!!! HELP
I need to change the distributor unit. The whole thing. Anyone has directions. Is there any caveats in this or it is simple to do.
Old 04-07-2003, 11:10 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
its very simple, there are three bolts holding the distributor onto your cam, after that when you remove the dizzy, make sure you remember which way the notch on the dizzy is positioned, on your new dizzy line that notch up the same way and put it on. check the timing and your set.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-07-2003, 11:58 AM
Thanks for the info. How do you check the timing?
Old 04-07-2003, 12:03 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
You need a timing gun because you change the timing by loosening the bolts and moving the distributor, so when you take it off you completely mess all that up. So you will need to get a hold of a timing light some how.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 04-07-2003, 06:46 PM
crxlvr's Avatar
any shop should be able to check your timing fairly easily and prolly w/o cost to you.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-07-2003, 08:11 PM
I DID IT! Changing the distributor was easy provided that one matches the shaft notches. My car is as good as new now. Thanks to all the advice I got on this website!
Old 04-07-2003, 08:15 PM
crxlvr's Avatar
another person helped on AF, what a great site we have.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-07-2003, 08:24 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
why did u need to change it what was the car doing>
Old 04-08-2003, 07:07 AM
Fiercecivic, the car wouldn't start. The battery and starter were new, I changed sparks plugs, distributor cap and rotor. Finally, I changed the whole distributor.
Old 04-08-2003, 09:08 AM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Did you check the timing to see where it's at ?
Old 04-08-2003, 09:13 AM
I am not sure what you mean. You can't insert the distributor withour matchning all the notches. The engine seems to be working very quitely so i assumed that the timing is ok. I need to buy "light" to check it right?
Old 04-08-2003, 09:45 AM
Yeah thats what i mean get a timing light so that you can set the ignition timing.
