new LIM gasket set, coolant, themostat, oil r2 too
no heat heat comes threw just a little warmer than ambient temp but both heater core hoses are hot used both bleeder screw to bleed system car doesnt over heat temp goes to the half way point and holds there dont hear any air in the system I'm using prestone coolant system was flushed also any Ideas |
Re: 2005 impala has no heat after LIM gasket/themostat
Sometimes you need to hold the idle up around 2k rpm with the cap off for a couple of minutes. Sometimes revving the engine will also help. I just had an alero that took me about 20 minutes of messing around to finally get heat after replacing the t-stat.
tried to bleed it again , now I have heat on the right side but not the left
also the heat smells like exhaust I've searched and found some people have had problems with actuators on the dual climate control systems. does anybody have a write up to fix or replace them |
found out it was only heat on the passenger side , swapped door actuator for the drivers side and it worked
